amp not giving sound to speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2007, 10:11 PM   #1 (permalink)
cardomain.com baggedcamry
BAGGEDCAMRY01's Avatar
View BAGGEDCAMRY01's Photo Gallery
3rd Generation amp not giving sound to speakers
i have a promblem my system is not working good .
promblem no sound coming out of my subs, i checked the amp it has power and checked the head unit sound coming out of the rear speakers but not the woofers. checked the wiring and still nothing. can my audio in the amp going out? i tapped the 2 rca jacks the speakers pops when rca jacks touch. can any one help me
BAGGEDCAMRY01 is offline   Reply With Quote
Old 05-28-2007, 10:14 PM   #2 (permalink)
xet
View xet's Photo Gallery
If the amp is getting power and rca signals, then make sure the power is getting to you sub. Recheck all the connections and test to see if it is getting the current
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 05-28-2007, 10:22 PM   #3 (permalink)
i checked all currents to amp and speakers everything is good then used a tester from radio it shows good as well i dont understand? this promblem
Old 05-28-2007, 10:45 PM   #4 (permalink)
View thereal2x's Photo Gallery
is your 12v turn on wire giving out power?
thereal2x is offline   Reply With Quote
Old 05-28-2007, 10:50 PM   #5 (permalink)
the 12 volt from amp is turning on the amp lights up
Old 05-29-2007, 06:55 AM   #6 (permalink)
atomix099's Avatar
View atomix099's Photo Gallery
Im having the same problem with two sets... Im guessin the amp is blown... On my set i messed up and had the gain @ max (mixed up gain and this other nob)... And on my friends set i burrowed giving me the same problem (same exact one ur having)... But when i plug in the rca cable sometimes i get a little like "pop" from the subs (like a split second of sound)... Thats the only signs of life
Have you tried using someone elses amp?
Tork Imagine Gloss Black 18x8-9/ 14% Tint - 20% Rear Glass
Kenwood KDC-MP208 / Premier TS-W1241C x2
http://www.cardomain.com/ride/2371652
atomix099 is offline   Reply With Quote
Old 05-29-2007, 09:39 AM   #7 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
When testing this stuff, i use a small radioshack amplified speaker. I hook this directly up to the RCAs to see if there truely is sound comming out of it. If your sure it's not the rca's then it's time to start swapping equipment. see if you can't hook the amp up to another set of subs (this is assuming that none of the fuses are gone on the amp and that all the gains are set properly). if this fails, time to swap the amp.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 05-30-2007, 04:38 PM   #8 (permalink)
well guys thanks for help. i found the promblem it was a ground wire. it was enough just give amp power to turn on . but no power to subs
Old 05-31-2007, 08:07 AM   #9 (permalink)
atomix099's Avatar
Really... Thats funny becasue my ground wire is hooked up to this screw end where my rear speakers is... im going to try moving it right now...
Edit: I hear a little bit of life in mine everyone now and then when i move around the ground wire... like a split second... Where is ur ground wire hooked up too?
Old 05-31-2007, 08:57 AM   #10 (permalink)
I smell McNuggets
[SMAN]'s Avatar
A strong ground is allways a good thing to have in a system. To help create a better ground, you should snad off the paint arount the bolt you are connecting to expose the bare metal. also the use of a spider washer (the one with the little legs on it) is great to use because as you tourqe it down, it will dig in making an even stronger ground. Most often, I bolt the ground to the seatbelt block. This area is usualy within a few feet of the amps and is a strong connection point.
Old 05-31-2007, 05:39 PM   #11 (permalink)
well atomix099 vbmenu_register("postmenu_1789210", true); did the ground wire work for u . thanks sman i would never thought of using that type of washer
Old 06-03-2007, 12:01 PM   #12 (permalink)
atomix099's Avatar
Actually my capcitor was the problem... Its funny because i would of never thought to run my subs str8... I leant out my capactor because my subs "werent workin" to find out his subs stop workin withit... So i hook mine up str8 and WHALA... Im back in the Game
Old 06-03-2007, 06:27 PM   #13 (permalink)
i never use cap on my subs i just go staight. well at least u found out the promblem
Old 07-02-2007, 07:53 PM   #14 (permalink)
Pimpin the Lesbo Blue Cam
View pudbrother's Photo Gallery
if the gain was set to high on the amp, could that blow the amp? im having this problem
pudbrother is offline   Reply With Quote
Installing speakers - '91 Corolla Dirtjump9 Audio, Video, and Security - Tech 2 06-25-2006 11:18 AM
no sound in right speakers.. celica2004 Audio, Video, and Security - Tech 2 06-10-2006 10:26 PM
what wattage amp kit should i buy.plus amp for woofer or speakers?? TheGhostCamry Audio, Video, and Security - Tech 3 11-22-2005 11:13 PM
Amp Installation help dave_thomas Audio, Video, and Security - Tech 6 04-29-2004 10:53 PM
Help?!?! Is it my amp or my speakers aladdin102 Audio, Video, and Security - Tech 7 10-21-2003 05:33 PM
