Originally Posted by JayMax03
Wait a minute... does that rule applies to subwoofers and amps also? I have a fan in the back of my HU and it is hotter than usual but everything seems to play fine
yes, that rule applies to subs n sub amps, too. if you're runninh hotter than usual, that's not good. it will eventually fail on you.
most decent sub amps can handle 2-ohm loads mono. but just check the amp specs to make sure. it will have a 4-ohm and 2-ohm rating.
before i knew about resistance and wiring (like 10 yrs ago), i wired a pair of 4-ohm subs in parallel, which gave a final 2-ohm load. then i hooked that up to an MTX amp in mono. the amp ran VERY hot after pounding bass. that amp was not meant to play mono at 2-ohms and it ran hella hot.
