components crossovers (boxes) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2007, 03:16 AM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 components crossovers (boxes)
i know most decent component sets should come with external crossover boxes to filter sound 4 the tweeters n midranges/midbass drivers.
my question is, do those crossovers prevent bass frequencies 80Hz or lower from playing thru the mids?
fredberg is offline   Reply With Quote
Old 06-02-2007, 08:05 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
it depends what the crossovers call for. they are different for each component set. can u post some info on your component set?
MrSo0h0o is offline   Reply With Quote
Old 06-02-2007, 02:46 PM   #3 (permalink)
fredberg's Avatar
Gen5
sorry man, i dont have any in mind yet. im guessin only the more expensive sets have good crossover options.
but dont most new amps have variable high-pass settings? that might solve the problem too?
Old 06-03-2007, 07:28 PM   #4 (permalink)
View dave_thomas's Photo Gallery
The crossovers with the component set should just split the upper frequencies to the tweeters and the lower frequencies to the midrange. To keep the bass out you will need another crossover but that will be the variable or at least adjustable high pass on the amp.
dave_thomas is offline   Reply With Quote
Old 06-03-2007, 09:15 PM   #5 (permalink)
MrSo0h0o's Avatar
oh i didnt realize you didnt have the comp set yet. some of the higher end comp sets have adjustable XO's. i believe if your amp has a built in XO, that will override the XO. do you have a HU yet? some HU's have digital XO's built in where you can set it all from there.
Old 06-03-2007, 10:17 PM   #6 (permalink)
fredberg's Avatar
Gen5
i have an Alpine HU with the iPod control. unfortunately, it's last year's model. i believe this year's Alpines, u can choose XO points from the HU. what a convenience that is!
what i was trying to get at was, trying to make sure that midrange drivers play within a frequency range. for example, the passive XO's that come with a component set wuld filter out the highs. then, an amp with a variable active XO would filter out the lows (say, 80Hz and lower).
Old 06-03-2007, 10:52 PM   #7 (permalink)
MrSo0h0o's Avatar
oh ok i gotcha.. well, most, if not all component sets will come with a XO that will send the correct frequencies to the correct speakers if thats what you are getting at..
Old 06-04-2007, 11:35 AM   #8 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Thats not quite true. IF you use the passive crossovers and try to go active....it would cancel each other out and make a different setting. In order to properly use the HU's xovers you need to remove the passive ones. PAssive xover blocks are tailored by the manufacturer but can be really limited as diffferent cars give diffedrent acoustics, that is why many people go active(besides the fact that they can choose how they want to hear their own speakers). THe passive crossovers is basically an active, excpet for the fact that the manufacturere selects what slopes and such are best, and sets them in stone, so you the user wont have to do anything. AS far as filtering out low frequencies from the mid bass, you would need an external xover that doesn't interferre with the passioves settings.
Webb26 is offline   Reply With Quote
Placement of crossovers MatrixirtaM 2nd Generation (2005+) 8 01-14-2007 09:25 PM
2 Ten inch boxes with Elemental Designs 11Kv.2s Rodge 2nd Generation (2005+) 0 05-14-2006 12:52 PM
4 inch components? wesscamrywagon Audio, Video, and Security - Tech 4 02-27-2006 08:58 PM
Need suggestions on new Components for my 2000 camry v6 xxpanipuri 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-29-2004 04:43 PM
suggestions on a new set of components... xxpanipuri Audio, Video, and Security - Tech 1 02-20-2004 03:26 PM
