System Setup and Grounding the Amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 10:29 AM   #1 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Smile System Setup and Grounding the Amp
Well after the suggestions of this forum, I finally decided to go get an amp and component set for the front stage of the Camry. This is my setup.
Currently, I have:
Kenwood DDX-6019 In-Dash DVD Receiver
Kenwood KNA-G510 Navigation Add-on
Kenwood KFC-X170 2 way speakers for Front
Stock Rear Speakers
What I'm adding:
Polk DB6501 Component Speakers for Front 100 Watts per chan.
Blaupunkt THA275 Thin Series Amp 75 Watts per chan.
I have deadened all 4 doors.
I don't have a a real car audio place in town to really sit and listen to speakers so I read a lot of reviews online about the Polk DB6501 and their predecessor, the Polk DB6500. They seem to be known for clarity and not harshness so the DB6501 seemed right up my alley.
As far as the amp, I was looking for something with adequate power (though I know more power is always better) with a small foot print so I could hide it under my driver's seat. The Blaupunkt amp seemed like a good idea since it has a small footprint and is pretty thin. Also has a clipping indicator. Hadn't read anything bad about the amp and it comes with a 1 year warranty.
My question is - Is this a good setup? And where can I ground the amp if it is installed under the driver's seat?
Thanks guys.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 06-05-2007, 01:51 PM   #2 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
Currently, I have:
Stock Rear Speakers
What I'm adding:
Thanks guys.
Well i don't know a lot about all the different amps, but i do know wiring. The seats unbolt real easily, it's jsut 4 bolts. As for that, just ground it anywhere you can make a solid connection to the body. find a bolt (other than the seat bolts) and attatch it there, be sure to grind the paint off of the area you are attaching the ground wire so that you make a good connection. It may also help to use a spider washer to help dig into the metal a bit.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Amp Installation help dave_thomas Audio, Video, and Security - Tech 6 04-29-2004 10:53 PM
Better grounding Blane Hardcore Tech and Competition 4 04-02-2004 07:30 PM
