well, a lot of it is all personal choice. You first need to go to your subwoofers manufacturer and find out what the recomeneded size of the enclosure needs to be (how many cubic feet) and then you need to decide how much space you have to work with. If you have the space, you can make a simple MDF box and carpet it. Making a sealed box is a lot easier than a ported one as the length of the port makes a big difference in the sound. If you are limited on space, you may want to consider going full fiberglass as it will ouline the most available space. The big custom setups that look like they are fully molded to take up the whole trunk often have an mdf base, but then again they aren't really pressed for space.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
