It's not worth trying. Your deck only has 4 channels so you would need an amp for your 5th speaker and you would not notice much of a difference. The only time adding speakers might be worth it: If you have an amp powering all your quality aftermarket speakers (so 4 channel, but 5 channel for the last speaker) and installed all the other stuff in your car yourself so you know what you're doing. Otherwise you waste a ton of time and some money on adding something essentially useless. You may want to add a sub though. If you're stock speakers can play highs and mids well enough, you can just have a sub or two provide the lows which will make a pretty decent sound setting for not too high of a price.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
