ohm rating on stock HU - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2007, 08:56 PM   #1 (permalink)
Toyota Nation User
4runnerracer's Avatar
View 4runnerracer's Photo Gallery
I recently got new component speakers. They are rated for 4 ohms. When I started to remove the stock speakers, the stocks are rated for 6 ohms. Can I use 4 ohm speakers with this headunit? Or will I need to change the HU or get a saperate amp?
01 Toyota Tundra Mods: Throttle Body coolant bypass - Differential breather extended - DRL disabled
4runnerracer is offline   Reply With Quote
Old 06-16-2007, 12:05 AM   #2 (permalink)
View jackie_ae's Photo Gallery
4ohm is the standard rating for speakers so I assume your HU can handle that 4 ohm speakers. Some HUs are made to handle 4-8ohm.
blog!
jackie_ae is offline   Reply With Quote
Old 06-17-2007, 09:30 AM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Your stock radio might run a little warmer, but it should be fine.
Pb is offline   Reply With Quote
Old 06-29-2007, 01:02 AM   #4 (permalink)
Toyota Nation User
Just wonndering, does the stock HU or other aftermarket HU's have a protection mode, like amps if you connect a 2ohm speaker that is only 4ohm stable?
stock hu???? xXwidowmakerXx Archived Corolla threads 2 05-04-2006 07:32 PM
Stock Hu trueasiatic Audio, Video, and Security - Tech 10 06-27-2005 03:33 PM
97 Camry HU replacement recommendations for the people who like stock calpchen Audio, Video, and Security - Tech 3 07-13-2004 06:40 AM
