got my speaker baffles from marv! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 11:30 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
ok i finally got my speaker baffles from mr. marv after a while(not his fault). here they are..
question now, should i try and prop the tweeters so they are at an angle towards me when i install?(hopefully tmrw)
also, whats the best method of drilling holes for the speaker screws to the baffle?
MrSo0h0o is offline   Reply With Quote
Old 06-15-2007, 11:54 PM   #2 (permalink)
View jackie_ae's Photo Gallery
where are you going to place those baffles? tweeters are better placed on the dash of on the pillars.
blog!
jackie_ae is offline   Reply With Quote
Old 06-15-2007, 11:57 PM   #3 (permalink)
MrSo0h0o's Avatar
front doors.. why would i put a component set in the rear deck :-P
i know dash or a pillars is better but i didnt want to cut up the interior and this was the best route to keep the interior stock.
Old 06-16-2007, 12:09 AM   #4 (permalink)
I have components on my rear deck..
why not use double sided tape then place it on the side mirror part or dashboard.? It would really sound better.
to answer your question, it would be better is you angle it upwards towards your ears.
blog!
Old 06-16-2007, 12:14 AM   #5 (permalink)
MrSo0h0o's Avatar
lol you mean permanently use double sided tape to mount them to the dash or door??
in my previous car, i had cut holes and mounted my tweeters in my a pillars. i found there was way too much separation going on.
Old 06-16-2007, 12:20 AM   #6 (permalink)
yeah. experiment with the placing of your tweeter. look for the best place that would satisfy your ears.
placing your component's tweeter beside the midrange would void the real purpose of components, it would only sound like a coaxial. the purpose of components is to separate the highs and the mids.
blog!
Old 06-16-2007, 04:29 AM   #7 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5
i bought similar MDF baffles from tacotunes.com. 3/4" MDF. but the corner edges (where the screws go) were too thick, i culdn't put the door panels back.
jus wondering if u are encountering the same problem.
fredberg is offline   Reply With Quote
Old 06-16-2007, 07:09 AM   #8 (permalink)
MrSo0h0o's Avatar
actually placing the tweeter close to the midrange is optimal due to separation. either way, i had the baffles made to house the tweeter also so i will see how it comes out.
fredberg, im gonna install today so ill get back to you.
Old 06-16-2007, 08:46 AM   #9 (permalink)
MrSo0h0o's Avatar
i dont remember what my old battery looked like but for the life of me i cant remember how i hooked the ring terminal to the battery.. so i decided to do it like this.. is this ok??
Old 06-17-2007, 09:29 AM   #10 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Yay for Marv. Nice baffles.
Pb is offline   Reply With Quote
Old 06-17-2007, 11:37 AM   #11 (permalink)
MrSo0h0o's Avatar
ok so i installed yesterday but silly me thought that CC would have my dash kit in stock but they didnt.. so i ended up just running my power and remote wires, wires for my HU brain underneath the pass. seat, and RCA's for components and sub. here are they few pics i took..
this is the location where i snaked the power wire through. its up and to the right of the brake pedal from the inside.
ran power wire along drivers side
removed HU trim, etc.
ran HU wires to brain along with other misc wiring i needed to run for the brain behind the glove compartment
this is how i left my wiring right now b/c i didnt wanna leave my amps by themselves in the trunk and im waiting on the dash kit and speaker wire
and this is the baffles mounted.. i know i still need to lay down my sound dampening, i have it in my garage but im gonna wait until i run my speaker wire.
so thats it so far.. hopefully i will be getting my speaker wire and dash kit by the end of the week so i can finish up my install on saturday.. feedback welcome!
Old 06-17-2007, 04:39 PM   #12 (permalink)
fredberg's Avatar
looks good so far. how will you run the wires behind the baffle? drill a hole and grommet?
Old 06-17-2007, 04:56 PM   #13 (permalink)
View canadiancelica's Photo Gallery
That is so far from the truth. component sets like that are meant to work together. The tweeters should either be 0-10 inches away or 24-30 inches away, with 0-10 being optimal.
canadiancelica is offline   Reply With Quote
Old 06-17-2007, 05:21 PM   #14 (permalink)
View thoughthard's Photo Gallery
When I mounted some tweeters in my modified Paseo door speaker mounts, I used some PVC endcaps to hold some Infinity Kappa tweeters. I can aim mine, so something to hold them was fine. Maybe you can utilize something along those lines...
thoughthard is offline   Reply With Quote
Old 06-17-2007, 07:57 PM   #15 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
I ended up mounting my tweeters in the stock location for the dash speakers. There is a little sound separation but not really bad. I wanted my sound stage to be up high. There was no flat surface to mount my tweets to in the door so the dash seemed like the best location. The tweets are angleable but firing toward the windshields either way. This isn't exactly what I had in mind but I think it turned out well. I might post pictures later on to see what people think of how I installed them.
Edit: Where did you mount your crossovers? Mine are just sitting behind my kick panels.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
FS: 2005+ Tacoma front midrange speaker baffles hcarman Car Parts for Sale 1 01-27-2007 05:50 PM
7" woofers and baffles For Sale Pb 2nd Generation (2005+) 20 10-28-2006 08:40 PM
foam speaker baffles gideon1331 Audio, Video, and Security - Tech 5 08-29-2006 10:04 PM
