well, right off the bat, i can't tell you what is wrong, i assume you get sound when your playing a cd, and the the wires you used for your ipod, you would get sound if you hooking it up to a regular TV. Also try hooking some other audio device in through the Aux in and see if you get sound there, if your only not getting sound from the ipod device and only when your connected to the CD player, then i have no ideas and you should talk to a kenwood tech. In theory, either you have bad wires, or a bad connections, so make sure the wires are outputting audio by hooking it up to the inputs on a tv, then test another device on the imput for your car stereo. most likely, one of those should also not work, and then you will know where your problem is.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
