Choosing an alarm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2007, 11:24 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Choosing an alarm
I have two questions on car alarms.
I checked the factory wiring diagram of a 99 Corolla and a 99 Camry. The pinout of the factory theft deterrent ECU are mostly identical except for the lead for starter relay (meant for starter disable) - 99 Camry have immobilizer system. The 2 connectors are identical. When I checked on 1sttoyotaparts, a replacement theft deterrent ECU for Camry is under $100, but the one for Corolla is like $260 Anyone know of any difference between the two? Can I use the 99 Camry one on my Corolla? If I am able to score these units, how do I go about getting the remote and have it programmed?
Also I checked the diagram as well as an instrument cluster. It seems like tachometer, power locks and power windows are exclusive to factory theft deterrent system. Is it possible?
If I am going aftermarket, which alarm system is the best? I want to be able to arm and disarm the system just by using my key to lock and unlock the doors as well as from the remote, have starter disable that I can expand to disable fuel pump as well, perhaps ignition too, turning it into an immobilizer system. I will be doing my own installation.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 07-04-2007, 01:12 AM   #2 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
The Viper Alarms are usually considered to be some of the best. However it is a rather difficult install. THis was the only think that I didnt install on my own car.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
DIY Modification Articles for the 95-04 Tacoma cam2Xrunner 1st Generation (1995.5–2004) 12 01-21-2010 08:05 AM
96 Camry RS-3000 Alarm Problems. HELP !!!! Steve Williams Audio, Video, and Security - Tech 0 05-22-2007 06:58 AM
Problem: Alarm – Immobilizer – TVIP – Intrusion jhaag 1st Generation (2003-2008) 8 12-09-2006 04:41 PM
Non factory alarm draining battery? 03 CE Corolla... Please help latstar Archived Corolla threads 3 01-28-2005 07:11 PM
