Alarm Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2003, 07:31 PM   #1 (permalink)
View yrmac's Photo Gallery
Alarm Install
Hey guys,
I need help with my alarm installation. I have a 95 Camry LE and I just installed an aftermarket alarm. Installation was fine, however, I am trying to figure out the parking light output for this car. Anyone know if the 3rd gen Camry needs a negative or a positive trigger to activate the parking lights? If it is negative, what/where is the location of this wire? Many thanks in advance for any input...
FUNCTION OVER FORM
yrmac is offline   Reply With Quote
Old 08-07-2003, 03:06 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Positive trigger.
+ / green wire / bottom of fuse box in a white connector
"Skoolin' the unlearned!"
Old 08-07-2003, 06:16 AM   #3 (permalink)
Originally posted by 88 LE
Positive trigger.
Dang! I was hoping it would be a negative trigger since my alarm uses a negative output. But in any case, many thanks for your help 88 LE...
FUNCTION OVER FORM
Old 08-07-2003, 10:44 AM   #4 (permalink)
View DIRTBIKEZ's Photo Gallery
Some alarms have switchable outputs. Maybe thats the case with yours.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 08-07-2003, 08:37 PM   #5 (permalink)
Ok..last question...
I would like to connect the door trigger input with this alarm. The alarm itself has a dual polarity of negative and positive inputs. Where is the best/easiest place to connect this door trigger wire?
Thanks again for any replies
FUNCTION OVER FORM
Old 08-08-2003, 12:55 AM   #6 (permalink)
Connect the negative (-) input from the alarm to the red and white wire comming out of the top right side of the fuse box.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
Old 08-08-2003, 05:19 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Theres also a negative trigger.
- / green / steering column
Heres a scan of the wiring info:
Old 08-08-2003, 06:19 AM   #8 (permalink)
Again, many thanks guys...now I know.
FUNCTION OVER FORM
