fabricating in-dash lighting help - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 07-17-2007, 02:21 PM   #1 (permalink)
Semper Paratus
jubrown57's Avatar
View jubrown57's Photo Gallery
Exclamation fabricating in-dash lighting help
I am installing a DIN size radio into my Double DIN space. I bought a Scoshe dash kit to install the radio but I didn't like the way the the shelf under the radio looked so I decided to mold in a rear lighted TRD OFF-ROAD symbol. I molded in a piece of tinted plexiglass, coated it with bondo and painted it black. It looks great but when I installed the LED's they barely lit up the design. It seems the LED's only lit up what was directly above the bulb. Is there a better lighting method to use or do I need more LED's? Maybe I have the wrong kind(I used 12 high intensity LED's)? I've seen this mod done in a magizine article but I cannot find the article now or locate any information on this type of mod.
Please help. I could really use the advice right now. If no one gives me any better ideas I might buy alot of low intensity LED's and make some sort of LED plate that covers the whole backing.
Thanks in advance
jubrown57 is offline
Old 07-18-2007, 10:26 PM   #2 (permalink)
Semper Paratus
jubrown57's Avatar
Just in case in anyone was wondering what I did to fix the problem,
I scrapped the tinted glass. swapped it out for etched glass. then I put a neon tube behind the glass with a mirrored box around it. worked out pretty well.
Old 07-19-2007, 07:57 AM   #3 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
you got any pictures I didn't even know what your what the post was about even though I read it
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline
Old 07-19-2007, 08:41 AM   #4 (permalink)
Semper Paratus
jubrown57's Avatar
Yeah I will as soon as I get it installed in the truck. It may be a little while. I'm expecting to get my exhuast system today. I'll most likely be spending my extra time this weekend putting that on.
It's not that complicated when you see it, it's just hard to describe it. Thanks for taking the time to look.
Closed Thread
Repairing a damaged dash Tacomahawk 2nd Generation (2005+) 3 08-22-2006 01:14 PM
How to change Dash Board Lighting ocean7blue 1st Generation (2003-2008) 3 06-10-2006 11:22 PM
need to find dash lighting wire nomad 2nd Generation (2005+) 5 01-13-2006 06:05 PM
01 GT- Dash lighting question. Dick Fitzwell Celica Forum 5 09-26-2005 09:41 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 02:38 AM
