Keyless Entry Remote Programming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2007, 09:04 AM   #1 (permalink)
'07 TUNDRA SR5
View e_zonana's Photo Gallery
One of my remotes for my '98 Sienna has somehow lost its programming. Any help will be GREATLY appreciated.
Remote has FCC ID: BAB237131-022
Eli
e_zonana is offline   Reply With Quote
Old 07-25-2007, 06:35 PM   #2 (permalink)
View thoughthard's Photo Gallery
Maybe this will help...?
http://www.automotiveforums.com/t483...ming_code.html
thoughthard is offline   Reply With Quote
Old 09-28-2007, 11:28 AM   #3 (permalink)
View Blue-Green's Photo Gallery
Here are instructions for 1999, so maybe it will work for you
1999 Toyota Sienna Programming Instructions
1. Start with key out of the ignition, driver door is open (all others closed),
and driver door is unlocked.
2. Insert key into the ignition (don’t turn it) and pull it out
3. Perform these steps within 40 seconds:
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles with lock.
Use an even pace and try to go about one cycle per second. 1 cycle = 1 lock and 1 unlock)
b. Close, then open driver’s door.
4. Perform these steps within 40 seconds:
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting
with lock.
Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1unlock)
b. Insert the key in the ignition cylinder.
c. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
d. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle automatically indicating successful entry
into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and
hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful
programming.
If the door locks don’t cycle, or cycle twice, repeat steps a and b-your remote has not
been accepted.
c. Repeat steps a and b in step 6 for each new transmitter.
7. Close driver door.
Blue-Green is offline   Reply With Quote
Old 09-28-2007, 11:45 AM   #4 (permalink)
'07 TUNDRA SR5
Thanks so much for the help. As it turns out, I have already sold my Sienna - replaced it with a 2007 Tundra, but will pass on your information to the buyer. I am sure she will be appreciative.
Eli
Eli
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 12:54 PM
Keyless entry remote programming help??!!??! JrFan Audio, Video, and Security - Tech 0 09-13-2005 01:05 PM
which keyless entry remote does 2001 Avalon use? avalon01 2nd Generation (2000-2004) 4 08-09-2005 11:39 AM
1994 camry keyless entry remote programming instructions camry528 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-20-2005 11:12 PM
94 camry keyless entry remote programming instructions amerellie 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-25-2004 12:15 PM
