Check all of your power ,ground, and speaker connections.
It sounds like you might have a cold solder joint on the amp somewhere, and as it heats up (or gets jiggled enough) it eventually makes its connection. It could do this for years, or could go out tomorrow. If the gear is under warranty, take it in, if not find a competent local repair shop, it should be a cheap fix.
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
