Starter Button - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2003, 02:56 PM   #1 (permalink)
View Turbo4barreL's Photo Gallery
Starter Button
Hey all, i was wondering if there was any way to wire a starter button into the ignition?
1987 camry w/ 227,000 mi.....beat up and getting ready to be fixed up
Turbo4barreL is offline   Reply With Quote
Old 08-11-2003, 05:14 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Like this?
http://www.miata.net/garage/pushstart/
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 08-11-2003, 06:34 PM   #3 (permalink)
yup, thanks
Old 08-11-2003, 08:13 PM   #4 (permalink)
bastion's Avatar
View bastion's Photo Gallery
hmmmmmm . . .
Master of Chen Long Freestyle Wang Fu.
bastion is offline   Reply With Quote
Old 08-11-2003, 09:36 PM   #5 (permalink)
rayray's Avatar
View rayray's Photo Gallery
i'm in the process of buying a DIN sized plate for my switches. they have an option for a starter button that peaked my interest for a brief second. you still need your key in the ignition turned almost on like you would with a car starter/alarm system. although the button has the coolness factor to it... you could just as easily turn your wrist another 10 degrees to start the car with the key as you normally would.
rayray is offline   Reply With Quote
Old 08-11-2003, 09:47 PM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
could wire a switch for accesories and one for the "on" position, and another to engage the starter
-Nick
Nick is offline   Reply With Quote
Old 08-11-2003, 09:48 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
hmm....that's a pretty cool idea, but I like the saab way better tho
HaHa
Old 08-11-2003, 09:53 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I like those switches Missiles, oilslick, machineguns
Old 08-11-2003, 10:03 PM   #9 (permalink)
Nick's Avatar
pssst that switch on the right is wired backwards...
-Nick
Old 08-12-2003, 11:59 AM   #10 (permalink)
I thought of the starter button idea for two reasons
1. it would just be something cool/different
2. if i hid it it could be used for security purposes
Old 08-12-2003, 01:38 PM   #11 (permalink)
bastion's Avatar
good point
Old 08-13-2003, 08:38 PM   #12 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Yeah but can you still start your car normally once you have the starter button? I mean, does it disable the keys' fuction, beyond having it in the ignition for security reasons?
You better never have a friend ride in the car with you. hah ha!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 08-17-2003, 03:08 PM   #13 (permalink)
i think it completely disables it, but i'm not positive
Old 08-17-2003, 08:53 PM   #14 (permalink)
Luc
View Luc's Photo Gallery
If you want to completely disable the "RUN" feature, you have to cut the starter wire inside the steering column. Basically, it's similar to how a remote start is wired up. Here is how I see it, you would need the push button with momentary (not toggle) switch and a 30-amp SPST relay.
1) One end of switch goes to 12V.
2) One end of switch goes to 85 terminal of relay.
3) Terminal 86 of relay goes to ground.
4) Terminal 30 of relay goes to 12V (use 12-gauge wire).
5) Terminal 87 of relay goes to starter wire on the starter side, not ignition side (use 12-gauge wire).
So you would just push the start button until the car cranks.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-17-2003, 09:36 PM   #15 (permalink)
would you still have to put the key in and turn it (that's what i would want)?
