Yes, sand or scrape down to bare metal for your ground. (although this will not help your starting problem)
Did you buy the amp new, has it ever worked?
Did you make sure your battery connections are tight?
Did you pound on the battery connection? (I have seen this screw up internal connections in the battery causing the car to not start)
Does it matter if the amp is playing loudly or just turned on at min volume?
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
