Big 3 Shorts Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 12:29 PM   #1 (permalink)
View s1138's Photo Gallery
Big 3 Shorts Out
Like many I decided to upgrade the "big 3". The car is a '90 camry.
I used all 0 gauge wire.
I ran it from the Positive Battery through a 250A fuse and connected it to the positive on the alterator.
I then ran a cable from the chassis to a mounting bolt on the alternator. The long one on the front pointing towards the ground.
Finally I ran a cable from the chassis to the negative battery terminal.
I went to reconnect the negative terminal on the battery and all I got were sparks and a crackling sound. The 250A fuse blew, along with the smaller stock 80A fuse.
I've rechecked the wiring. Made sure the chassis points are bare metal.
What am I doing wrong?
s1138 is offline   Reply With Quote
Old 08-07-2007, 02:10 PM   #2 (permalink)
View Mr Marv's Photo Gallery
Can you post pictures of how everything is connected?
Mr Marv is offline   Reply With Quote
Old 08-07-2007, 02:39 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $268523
View Buurin's Photo Gallery
This is highly suspect.
Little Pig. You are ready.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-07-2007, 05:51 PM   #4 (permalink)
That's what I was thinking
Old 08-07-2007, 07:26 PM   #5 (permalink)
Where would be a good place to run that wire to?
edit:
Ok, I found an engine picture online and MSPainted it.
The Blue is the positive from battery to alternator.
The Green is the negative battery to chassis.
The Red is the mounting bolt off the alternator to the chassis.
http://img61.imageshack.us/img61/1434/big3ro4.jpg
Old 08-08-2007, 01:25 AM   #6 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
Looks right to me.. but the only way those fuses are popping is if the wires are flipped...
Corollacrazy42 is offline   Reply With Quote
Old 08-08-2007, 10:10 AM   #7 (permalink)
wires flipped?
I am not quite understanding that.
Old 08-08-2007, 11:08 AM   #8 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
dissconect the one from the alternator mounting bolt and see if it still shorts.
Curry is offline   Reply With Quote
Old 08-08-2007, 11:33 AM   #9 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
This is why it is allways good to meter your connections. I would get a multimeter and check the connection between your alternator and ground. If you see +12V, you know you shouldn't hook it up to there. In the long run, this will save you time, blown fuses, and a potentialy deadly hazard.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 08-08-2007, 06:31 PM   #10 (permalink)
That One Guy...
flipped... as in reversed polarity. Negative on the postive, positive on the negative nonsense.
wires flipped?
Old 08-08-2007, 06:34 PM   #11 (permalink)
That One Guy...
Also.. I think you should connect your engine ground to the actual engine block and not the alternator. You may have a bad grounding point putting it on the alternator.
Old 08-08-2007, 09:19 PM   #12 (permalink)
Is there a specific place I should put the wire on the engine block. Or would any bolt do?
I did notice one thing today when I was looking. Originally, there was the positive to alternator. And then there were 2 wires running off the negative terminal. One went to the chassis, and the other mounted on top of the transmission.
Could I disconnect the negative to the transmission, and run a new wire from the transmission to chassis?
Old 08-09-2007, 02:34 PM   #13 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $355745
View atobe's Photo Gallery
i think your blue wire is shorting out... only reason i would see a 250A fuse blow... your alternator only puts out 70A. also your red wire does basicly nothing.
there's a few grounding wires on the car.. battery to tranny,chassis as u stated... if you look near the alternator.. there's also another going from engine head to chassis. there's also another below the battery that connects the tranny to chassis.
what i did in my car was get a battery terminal and got 2 4 gauge wires.. ran one to chassis.. one to tranny... replaced all the other ones with some left over 10 guage wires. never did the alternator+ to battery+ though.
atobe is online now   Reply With Quote
Next Big So Cal Meet 7-10-05 rollasunited Regional Meetings and Events 16 06-13-2005 04:03 AM
When big boobies go bad... *ww* CamryPunk Off Topic 28 04-09-2005 03:07 AM
Removing top big interior piece. gqdabien Camry & Solara Lounge 1 09-30-2003 04:44 PM
