I went to DEI's website, but they list no wiring for the '94. If you have a meter, probe the wires at the factory amp for the wire that has +12 volts whenever the stereo is on. I would think that the power antenna lead would still work, just tap into the wire and off you go. Sorry I don't have actual wire colors, but all my info is for gen4's.
In my haynes the antenna wire is red/blue coming out of the radio and the amp turn on wire is red, but again THESE ARE FOR THE GEN4. If you dont have a meter do not just start trying each wire to the amp, this is a recipe for blown fuses or worse. Find a buddy w/ a volt meter or go buy one you will use it plenty!
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
