Questions about 03 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2007, 05:30 PM   #1 (permalink)
View cadmium's Photo Gallery
Hello Eveyrone, I just got a used (new to me) Camry LE 03. Unfortunatly, it does not have the JBL Audio package (but is great otherwise). I had a few questions about some basic aftermarket upgrades.
My ultimate goal is to not spend too much ($500-700 *ideally*) and have reasonable audio as well as Sirius Radio.
My initial thought is to get an entry level head unit such as a Kenwood DPX302 or similar and re-use my SIR-KEN1 tuner from my last car if I can (I know that running the sirius through the HU reduces the experience compared to a stand alone unit, I'm okay with that).
Also, everything would be professional installed. I feel comfortable doing a head unit, but I ran the antenna for the sirius in my last car and that was enough.
My questions about this are:
- Will the head unit improve the overall sound quality of the stock speakers?
- Is it worth it getting a cheap amp for the stock speakers?
- I've read the stock speakers are a custom size and any aftermarket speakers require extra work to install. How much of a problem is this for professional installers (ie does it cause damage to the car or get really expensive)?
- How is the installer likely to run the Sirius antenna? Whats a common installation for Camry's?
-Whats the best use of my money here?
Again, I'm hoping for "good enough" here not perfection - which I respect, but can't afford
cadmium is offline   Reply With Quote
Old 08-19-2007, 12:51 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
Do not use an amp for the stock speakers. If you have an aftermarket radio with about 20W RMS the stock speaker will be ok. If you amp to higher than this you'll risk blowing them because I think the stock radio puts out less power than this.
The speakers are 6x9s in the doors and in the back. The speakers have custom designed bracket for mounting, but you can put any 6x9 in by drilling a few hole or you could make or buy an adapter.
2007 Camry 2.4L 5M
Old 08-22-2007, 12:27 PM   #3 (permalink)
Thanks for the info. At this point I think I'll stick with stock speakers (for now) and I'm trying to decide between a new head and compatible sirius tuner or just keeping it simple and going with a Sirius sportster or similar. Since I've has Sirius, I don't really listen to many mps
'95 Camry.. Going for bigtime maintenance/tune-up.. questions roper512 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-01-2008 03:38 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 04:43 AM
JDM Camry 03 Headlight (56k beware) OrangeJuice 5th & 6th Generation (2002-2006 & 2007-2011) 7 07-20-2005 07:25 AM
'03 Lexus ES300 VS '03 Camry VS '03 Mercedes E320 Lorinser Camry Gen3XLE General Lexus Discussion 8 04-23-2003 08:11 PM
'03 Camry VS '03 Lexus ES300 VS '03 Mercedes E320 Lorinser Camry Gen3XLE 5th & 6th Generation (2002-2006 & 2007-2011) 9 01-09-2003 08:03 PM
