wiring an amp switch? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2007, 08:11 AM   #16 (permalink)
audionut71's Avatar
View audionut71's Photo Gallery
How about some pics?
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
audionut71 is offline   Reply With Quote
Old 09-04-2007, 01:35 PM   #17 (permalink)
View mafia29's Photo Gallery
will get some pics up soon ...
already put everything back together ... lol but will get some DIY and final product pics!
mafia29 is offline   Reply With Quote
Old 09-23-2007, 10:07 PM   #18 (permalink)
pics!
finally got some damn pics ....
http://www.yourfilehost.com/media.ph...e=DSCF0253.JPG
blew the stock 6 x 9's ... so these are my new (old ones) with my custom brackets made from really damn thin mdf ...but i broke one of the original screws off that holds it to the rear stamped metal plate... so i cant get any new ones to hold as tight ...
http://www.yourfilehost.com/media.ph...e=DSCF0237.JPG
a view from the back seats .... not fullly wired
http://www.yourfilehost.com/media.ph...e=DSCF0238.JPG
power wire and remote wire running behind the rear seats and down the passenger side
http://www.yourfilehost.com/media.ph...e=DSCF0240.JPG
this is where the power wire goes up through the firewall ... behind the panel on the front passenger side
http://www.yourfilehost.com/media.ph...e=DSCF0242.JPG
switch for the remote wire that goes into the lighter/power behind the center stack
see that little hole ont he left a bit? thats where that screw popped out... how th ehell do i put i tback?
http://www.yourfilehost.com/media.ph...e=DSCF0245.JPG
view of the back from outside
http://www.yourfilehost.com/media.ph...e=DSCF0246.JPG
http://www.yourfilehost.com/media.ph...e=DSCF0247.JPG
a view from inside rear seats into the trunk
http://www.yourfilehost.com/media.ph...e=DSCF0249.JPG
http://www.yourfilehost.com/media.ph...e=DSCF0251.JPG
power wire through existing hole in firewall and grommet...
cut slit in grommet fished wire with coathanger down to the floor of the passenger side
http://www.yourfilehost.com/media.ph...e=DSCF0252.JPG
http://www.yourfilehost.com/media.php?cat=image&file=DSCF0253.JPG
ran the power wire against the firewall down the driver side to the battery ..ran outa the heatsheild crap
hmm i forgot to take apic from outside looking into the trunk.. ill do that tmrw!
whats the best way to hold the damn sub in place? i velcroed it to the carpet ... but the whole carpet moves! should i velcrow the carpet to that wooden piece that covers the spare?
Old 09-24-2007, 05:46 AM   #19 (permalink)
audionut71's Avatar
Glad everything is up and running. Here's a few tip to keep everything running well.
1. Wire nuts are not made for automotive wire (wire nuts are made for home wiring which has solid conductor or stranded wire with fewer thicker strands, the wire we use has much finer wire and many more strands) and will not be reliable in the long run (they were not designed to be in a moving vibrating vehicle, they are made to live in a snug little box inside your wall). Go get some crimp caps and a crimper, they will hold up to vibration and general abuse much better.
2. Zip tie those wires up! It looks better and is far less likely to get them caught on something going into or coming out of the trunk.
3. Screw the box to the floor, velcro is almost never enough, and the adhesive on it will give out. Or csrew it to the opening behind the back seat.
'99Camry LE I4
Old 09-26-2007, 12:37 AM   #20 (permalink)
yeah i know about the wire nuts... just cant think of what else to use besides crimps
so i think my speaker rear is shorting... it crackles .... could it be shorting from improper wiring to the speaker plate?
Old 09-26-2007, 07:46 AM   #21 (permalink)
audionut71's Avatar
wiggle each of the connections and listen to when the speaker crackles, that will tell you which one to fix. I would start looking where you have added connections recently.
I used wire nuts when i did my 1st install and had tons of problems, the crimper is your friend. I have been there.
'99Camry LE I4
wiring tweeters without Amp Troyfrezze Audio, Video, and Security - Tech 18 12-22-2006 03:37 PM
Open channel on amp / speaker wiring touringcamry Audio, Video, and Security - Tech 5 06-28-2005 12:59 AM
