wiring an amp switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 07:01 PM   #1 (permalink)
View mafia29's Photo Gallery
95 Camry
stock HU, with power antennae
i have a toggle switch, i want to run it to my amp so i can kill the bass but still hear the music through the rest of the speakers....
so,
1) amp -> remote wire to toggle switch (1 side) -> same gauge wire (other side) to HU
antennae control?
-would this make sure my amp is def. not on, especially if the radio is not on and the switch may be in the on position?
2) amp -> remote wire to toggle switch (1 side) -> same gauge wire (other side) to a fuse that turns on when the car is on, by using a fuse tap?
-and if this is the case, which fuse can i tap into?
or what do i have to do?
thanks.
mafia29 is offline   Reply With Quote
Old 08-22-2007, 10:13 PM   #2 (permalink)
View Mr Marv's Photo Gallery
#1 will work fine.
Mr Marv is offline   Reply With Quote
Old 08-23-2007, 12:39 AM   #3 (permalink)
View toyota_b's Photo Gallery
I was going to do the same until i found that kenwood was nice enough to think of that for me now its just a push of a button.
toyota_b is offline   Reply With Quote
Old 08-23-2007, 01:02 AM   #4 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
my pioneer does that but you'd have to go through the sub config though and it doesn't turn the amp off just the subs
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 08-24-2007, 11:56 AM   #5 (permalink)
View Tragedy's Photo Gallery
I'd do #1... that way your amp won't be on when your radio isn't on, and you won't have to bother with a fuse tap.
Tragedy
2007 V6 Camry SE
Tragedy is offline   Reply With Quote
Old 08-26-2007, 09:39 AM   #6 (permalink)
ok
ALright, #1 it is ... do i have to use a specific electrical wire to run from the switch to the HU or can i even use a telephone wire ... got awhole bunch of it?
From the switch to the HU, is there a place where i can attach the switch wire or will i have to splice/solder it into the antennae remote wire?
And, how do i get my HU out without disconnecting it all, to attach the switch wire?
And once i disconnect my battery to connect my amp power wire, i will have to go to the dealer to get the security code for the HU?
Is there a DIY on running amp wire to the trunk, ie. how to remove inside panels, slip wire through existing firewall hole, removing carpet, etc.?
Old 08-26-2007, 10:10 AM   #7 (permalink)
audionut71's Avatar
View audionut71's Photo Gallery
Go to an autoparts store or stereo shop and get some 16 or 18awg stranded wire (phone wire, assuming that you have the in-wall stuff, is a solid conductor, and that won't go well with the vibrations in a car).
Anywhere that you want. You will have to splice into the wire. My fav way is to strip off a 3/4" section of insulation(without cutting the wire), poke a pick tool (or whatever) thru the middle of the strands, push the wire that you are attaching thru the strands, and then twist-solder-and tape. If you don't have a friction stripper you can strip the wire with a razor blade.
I think it would be easier to just unplug the deck, but whatever you want to do.
Sorry, not a Gen3 guy. Don't know this one.
Have not seen a diy, but have seen mention that Gen3's (and 4's) have a nice big grommet on the drivers side beneath the splash guard lining the front wheel well. Pull as many of the screws-clips out of the backside of the wheel well liner as you need to to expose the grommet and cut a liitle slit in the grommet and run the wire thru there.
Hope this helps.
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
audionut71 is offline   Reply With Quote
Old 08-27-2007, 02:38 PM   #8 (permalink)
i have a 12 awg/strand (20amp) wire... is this good enough to connect to my switch and splice into the HU?
Old 08-27-2007, 05:11 PM   #9 (permalink)
audionut71's Avatar
Plenty, you could go as small as 18 awg safely.
'99Camry LE I4
Old 08-28-2007, 12:02 PM   #10 (permalink)
sweet...
now how the hell do i get that wire from my switch to the back of the HU?
Old 08-28-2007, 10:18 PM   #11 (permalink)
audionut71's Avatar
First off Pull the deck out of the dash I forgot to ask, where is the switch gonna live?
'99Camry LE I4
Old 08-28-2007, 11:02 PM   #12 (permalink)
i dont know... iw as going to put it where there are cut outs molded into the dash... but goddamn i dont want to cut that out! ... so i might just stick it in just left to center stack ... where there is a space b/w the front panel and middle panel...
Old 08-28-2007, 11:13 PM   #13 (permalink)
audionut71's Avatar
I'm not sure what you are not clear on yet, so I hope this is not insulting.
OK sooooo
1. Pull deck out
2. Splice into antenna remote wire (directed lists 2 possibilities:black/red and pink/blue)
with some of the wire that you have and run it down to where your switch is.
3. Connect the wire that you just ran to one side of the switch, and connect another wire that you will run all the way back to the amp to the other connecter on the switch.
4. Drink beer, you are done.
'99Camry LE I4
Old 08-29-2007, 11:23 PM   #14 (permalink)
lol thanks man ... i know the questions sound dumb... but honestly, i aint that dumb, i drive a camry ! lol
i know all that stuff man, but what i mean is... where the hell should i exactly position my switch .... like when i attach the wire from the switch to the antennae... obviously it doesnt run 'into' the back like all the other wires... im going to have to pull it through to the front at some point ... and i was wondering... for that to happen, where would the best place for the swtich be and how to exactly run it to the front of the car...
kinda get what im saying?
Old 09-01-2007, 06:33 AM   #15 (permalink)
DONE!
spliced my switch wire into the cigarette lighter ... ran it behind the HU down the passenger side ... remote wire back to amp ....
any placement suggested for power wire in engine bay? i ran it against the firewall.. but im coming up short a bit, im going to have to pull it through.. but i just twist tied it to what i think is the throttle line for now.. is that ok for temp. use?
wiring tweeters without Amp Troyfrezze Audio, Video, and Security - Tech 18 12-22-2006 04:37 PM
Open channel on amp / speaker wiring touringcamry Audio, Video, and Security - Tech 5 06-28-2005 01:59 AM
