run the rca from the deck to the amp, it seem like your deck only have front and rear input, justr connect it to the front input and run it to the amp,
there is a blue/white wire on the deck harness, connect it with a remote wire for your amp,
so i just hook the yellow wire coming out of the back of the sub to the positive side of the battery?
its a built in 'active' subwoofer by Jensen 100w RMS, 380w peak, its cheap but its what my cheap bastard friend got lol... i swear his 88 ford taurus has like $500 worth of electronics in it.... i'm helping him hook it up cuz he's about as 'car savvy' as lindsay lohan
so from what i understand so far is
from the harness with the blue/yellow/black wires:
black = ground
yellow = power (but does it hook right into the positive terminal of the battery?)
blue = hook to rear of headunit to the wire that says "AMP REM MAX 0.3v" ??
get rca wire and hook it from the l/r front sub output of the headunit into the l/r input of the subwoofer...
what the hell are the rest of the wires for? and the second harness with the 2 sets of black and red wires (the pic thats 48kb)?
Looks like you're on the right track... I've made some notes below.
It looks like there are 3 ways to get the stereo signal to this amp:
1: RCAs (recommended)
2: High-level Input (tapping your current speakers for the signal)
3: Headphone-type adapter
I've noted which cables are for what below.
Originally Posted by whatproblems
so my friend just got in his subwoofer, and we're stumped on how to hook it up
thats the back of the subwoofer...
it came with 5 of these wires This is for option #3 (see above, I wouldn't recommend it). You would plug this into a headphone-style line-out jack, connect the cable with the spaded connectors (see below) into the ends, and then the other ends of those cables connect to the high-level-input harness. This cable is black for both wires because it only grabs the audio from one channel and splits it. NOT NEEDED IF USING RCA!
all i know is the black is ground.... As mentioned, the blue is the remote turn on lead... this is how your radio tells the amp to turn on and off. Note that if this cable is not connected, your amp will NOT turn on, even if you have the power and ground cables connected. The ground should be grounded to bare metal on the car (it's recommended to scrape paint off at the grounding point if there's any). The yellow power wire should run to the battery, and be fused (it's recommended to put it between 18" and 36" from the battery). Adding a fuse protects both your amp and your car... even on small setups it's always a good practice to follow. Some setups come with fuses buried in the box somewhere... if not, look for a 30 amp in-line fuse.
no clue at all what this is Used to connect the mono headphone-jack style cord (black one pictured above) to the harness pictured below. NOT NEEDED IF USING RCA!
nor this Connects either the headphone-jack-style cable (above) OR the High-Level Input cables (below) to your amp. NOT NEEDED IF USING RCA!
this too If you weren't using RCAs you would tap these wires into existing speaker wires on one end, and connect the other ends to the wiring harness above. NOT NEEDED IF USING RCA!
and thats the rear of the headunit
there is also an unused wire that says AMP REM MAX 0.3v sticking out of the rear of the headunit
any help is GREATLY appreciated!!!
You're already on the right track... I hope this clears up any confusion. Good luck!
yes. If there's a short, you want it to pop the fuse close to the battery instead of at your amp... it's a fire hazard. Here's a few links with some info about that and other general tips:
P.S.... if it slides around your trunk and you don't want to bolt it down, get some velcro... use the hook side (hard plastic side) of it on the bottom of the amp&sub and it'll grab on to the carpet
