how to install grommet/alternatives at firewall after running the cable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2007, 02:13 AM   #1 (permalink)
View nobitanobi's Photo Gallery
4 gauge amp power through a hole (more oval than circle) i drilled on the driver side firewall, i can't make the hole any bigger because the drill bit just wont stay still on the sheet metal while angled. i was thinking about just glue the hole shut so the 4 gauge wont be grinding on the sheet metal. anything else easy and dependable i can do ? thanks
nobitanobi is offline   Reply With Quote
Old 08-27-2007, 10:06 AM   #2 (permalink)
View frankierx's Photo Gallery
Yes, under above the gas pedal is a rubber gromet that you can cut a hole into and fit your 4 gauge wire. I did it but never used it completely to install my amplifiers. I ended up taping the hole back up with electrical tape because I opted out of the amplifier set up.
frankierx is offline   Reply With Quote
Old 08-28-2007, 08:31 PM   #3 (permalink)
View toyota_b's Photo Gallery
Thats what i did i put 1/0 through mine... I have done the same thing on a few of my installs on diffrent cars. never had a problem either. Thats what i would say could be your best bet. you could get some rubber plugs and put that in there if need be or just elct. tape it.
toyota_b is offline   Reply With Quote
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 02:37 AM
89 celica speedo cable leak--help tspieker Celica Forum 6 01-21-2006 12:33 PM
89 celica speedo cable leak--help tspieker Celica Forum 1 05-11-2004 09:45 PM
Partial NASCAR Truck Race Results Sportivo Concepts General Discussion 4 02-15-2004 12:22 AM
DAYTIME RUNNING LAMPS: Easy to Install?? thisdj78 Camry & Solara Lounge 6 08-04-2003 04:57 PM
