subwoofers popping??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2007, 11:45 AM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation subwoofers popping???
I didn't think much about this until yesterday, but my subwoofers started popping it was only for a little bit. In case any1 doesn't know I had an car accident 2 Fridays ago; my drivers side headlight, bumperlights, cornerlight, and some part of my fender is bented up. My headlamps still works, but the rest of the lights don't work anymore I think the wires might have been stripped. Anyway I was driving home and my subs were playing just fine then they started phazing in & out then there was some popping sounds. I pulled on the side of the road and checked some things out and here's what I noticed...
1. Inline fuse - the plastic part of it is cracked and the fuse is jumping I mean isn't it suppose to be a tight fit where it shouldn't move? its a 70 amp fuse just incase it comes up
2. Amp - when I stopped it when into protection mode for 5 minutes flat. I turned the car off the turned it back on it came back on. It was hot to the touch. It rained when the sun went down so the sun could something to do with it. All of it happened at daybreak (around 2:00 to 5:00)
3. My voltage used to drop at moments notice but now I start the car up its 14.5v and after a while it goes down at 13.8v. It used to drop at 11.9v, but ever since that accident... I don't know??? My lights stopped dimming now, but that still worries me.
4. At one point of the time there was I guess a power boost like I had a CAP installed (which I don't have) and then I thought one of the subs had blown. I checked there still playing fairly well. Thats when the popping started...
I have a 4 gauge power cable and 4 grounding cable (grounded under the bench seats)
(TMA TAK4 amp kit)
If I notice anything else I'll post it up...
I just want to know before something actually does go wrong never can be too careful you know!!!
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 08-28-2007, 12:33 AM   #2 (permalink)
JayMax03's Avatar
ok its official the amp is completely off now no protection mode no power period. I might have to check the inline fuse but other than that its out
Old 08-28-2007, 11:38 AM   #3 (permalink)
JayMax03's Avatar
the fuse is fine it just came back on this mourning. This is getting weird now. I might decide to buy another amp kit
Old 08-28-2007, 11:53 AM   #4 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Have you checked your wiring?
I would go over all the wiring from beginning to end. It sounds like it COULD be a wiring issues. Replace the entire fuse holder and fuse as a precaution. But double check the wiring first.
Curry is offline   Reply With Quote
Old 08-28-2007, 02:14 PM   #5 (permalink)
JayMax03's Avatar
the fuse holder got exposed with some water I don't know how though?? all the damage is in front the drivers side of the car. everything is wired from the passenger side of the car. I never had the popping incident before my accident, but I get the feeling there is a lot more to come.
Radio popping on acceleration LoneTacoma 2nd Generation (2005+) 2 05-08-2007 02:36 PM
Popping Noise when turning the wheel kimmcc RAV4 Forum 5 08-11-2006 02:33 PM
I think my newer/bigger tires make a popping sound. Why? Don2000g 2nd Generation (2005+) 6 08-03-2006 07:39 AM
6.5" subwoofers? mauibuilt59 Audio, Video, and Security - Tech 15 01-20-2006 05:48 PM
