grounding wires and how to wire amp, subs, etc? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2007, 12:35 AM   #1 (permalink)
View mafia29's Photo Gallery
95 V6 LE ... Stock HU ...
ok so since im running my subs off my back speakers ....
ill have to :
1) Sound
splice into rear speakers with speaker wire -> run those into my hi/low stinger adapter (but where do i ground that little brown wire to? do i need to run a longer wire to connect it and ground it?) -> connect the rca's into the amp (where do i ground the rca's?)
2) Remote
remote wire from amp -> to switch -> wire from switch spliced into remote antennae wire (if i use the tape function after turning the radio on, will it shut off my amp?)
Can i run the remote wire on the same side as the power wire?
3) Power
Running my 8 gauge wire... from reading and looking, ive located 2 spots where i can go through the firewall w/o drilling new holes ... the passenger side and the wheel well of the driver side.
What carpet and panelling do i have to remove to get it through the passenger side?
If i go through the wheel well, where does it go inside? where will it feed into the engine bay?
4) Switch
How the hell do i take off the dummy plate so i can cut it and put my switch in it?
Does the switch need to be grounded?
5) Sub
How do i wire my sub to be bridged?
I think thats it... thanks guys!
mafia29 is offline   Reply With Quote
Old 08-28-2007, 11:44 AM   #2 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
1. what car are you putting it in?
2. you don't ground the rca's they go from your amp to your headunit
3. yeah you can run your remote on the same side to the power wire just don't connect them
4. this refers back to question one but if you're in a gen3 Camry I assume your talking about the plates above emergency brake
you might wanna put some pics up
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 08-28-2007, 12:00 PM   #3 (permalink)
Yeah i didnt think you had to ground the RCA's , but they come with this little wire that has a ring plate on the end... looks like a bloody grounding wire....this is from blackhawk's post
but those red circled things ... next to the steering columns is whatim talkn about to put a switch in.. unless there is an easier place?
http://www.yourfilehost.com/media.ph...IMG_1644_1.jpg
Old 08-28-2007, 12:02 PM   #4 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
If the RCA has the brown ground then just use it to help keep the noise out. Avoid extending it. The longer the ground the more pointless it will be. Electricity likes to take the shortest path.
You should tap the remote wire from you're headunit.
Don't be lazy. Drill a hole thru the firewall and bring the cable in and tuck it under the panels. You won't even have to pull them.
Pry the dummy plate off with a flat head, but a piece of cloth over to tip so you don't damage the dash
You don't bridge subs you bridge amps. Refer to your amplifier manual.
Also some information on the equipment your using would be much more helpful...
RCA brand/type... amp model and make, sub make and model... just to name a few.
Im assuming you didnt want to change the headunit?
Curry is offline   Reply With Quote
Old 08-28-2007, 12:03 PM   #5 (permalink)
Curry's Avatar
Theres no space behind those things to put a switch. use the black plate thats a little above.. its much better.
Old 08-28-2007, 12:11 PM   #6 (permalink)
yeha sorry to sound liek such a noob ...
Amp: JBL GTO75.2 ... 2 chan.
Sub: 12" JBL GTO1204D ...
i just have some generic cables ... bought an amp kit....
yeah im looking to tap the remote wire into my anetenna wire .... i guess i can put a switch anywhere really.. and double side tape it .... how do i get the wire to the deck.. meaning what panels do i have to take off, besides the ones required to get the HU out?
Old 08-28-2007, 12:13 PM   #7 (permalink)
and id really rather not drill new holes... not being lazy completely ... if there are already is a grommet i can slip it through.. id much rather that... i read there is also one, behind the brake pedal?
and yes, i dindt want to change the stock HU ... im only around for a few months... so my mother stil drives the car!
Plug Wires and replace seperately ? retiredat44 Archived Corolla threads 3 02-13-2007 01:04 PM
would anyone be interested in a grounding kit? Trixter Archived Corolla threads 11 02-15-2006 08:08 AM
Tercel Clock wires? Help? gezebo Tercel, Paseo, Starlet, and Sera Forum 7 01-03-2005 04:44 PM
grounding wires? userlain Camry & Solara Lounge 7 10-10-2004 03:58 AM
