IB install 2002 Camry(PIX)... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2007, 08:00 PM   #1 (permalink)
bigloubumpin's Avatar
Gameroom cash: $150645
View bigloubumpin's Photo Gallery
They're the eD EHQS SVC 2ohms subs.Here's the link to the review & a couple of pix..... http://www.diymobileaudio.com/forum/....php?t=19000l]
bigloubumpin is offline   Reply With Quote
Old 09-02-2007, 08:56 PM   #2 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5
very nice install! i've always thought about doing this, jus so I culd get the sound/volume of a pair of 12's, w/o having to take up trunk space with a big box.
i'm assumin u sealed the rear deck and the baffle side as much as possible. so im wondering how it sounds, considering that facing a normal box frontwards has some bass/phase cancellations.
and what did u use as a template to cut the baffle board?
great job once again. i will def look into this IB install myself again.
fredberg is offline   Reply With Quote
Old 09-02-2007, 09:44 PM   #3 (permalink)
The rear deck & baffle was sealed using deadening. These drivers require a rather large enclosure if sealed or ported,they're IB capable according to eD.No cancelation issue either,I have them running in reverse phase just by a flip of a switch on the amp.I used some poster board for a template then traced the shape onto the MDF.
Old 09-03-2007, 12:33 AM   #4 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
where did you mount your amps? on the back of the rear seats? i like this setup a lot, where in ny do u live, can i borrow your template? :-)
MrSo0h0o is offline   Reply With Quote
Old 09-03-2007, 01:01 AM   #5 (permalink)
Amp is under the rear deck,I'm in Suffolk Cty....
Old 09-03-2007, 05:03 AM   #6 (permalink)
fredberg's Avatar
Gen5
Big Lou,
i'm diggin ur setup. my other question is...Is the baffle board in front or behind the sheet metal opening? or is it flush?
and ur amp. i'm assuming its mounted to some MDF under the rear deck, yes?
btw, do u lose any volume when the rear seats are up and covering the sub?
Old 09-03-2007, 04:58 PM   #7 (permalink)
The baffle is behind the opening, a piece of MDF cut to the size of the amp was secured to the reardeck then the amp secured to that.There's a just a slight difference in output w/ or w/o the seats down but still happy with the output all things considered.
Old 09-05-2007, 09:17 PM   #8 (permalink)
fredberg's Avatar
Gen5
big lou,
ok, some final questions...so the baffle is behind the opening...how did u attach it to the surrounding sheet metal?
i'm guessin L-brackets at the top and bottom?
and maybe bolts through the sheet metal around the sides?
i'm ready to start this project this weekend, so please holler back!
Old 09-06-2007, 12:24 AM   #9 (permalink)
Originally Posted by fredberg
big lou,
L-brackets at the base of the baffle,I used three total(watch out for the gas tank-PLEASE!) & sheet metal screws thru the sheet metal itself into the baffle around the sides & top.The baffle is sealed off with deadening,good luck.
Old 09-07-2007, 10:04 AM   #10 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
The setup looks sweet... gotta love ED.
Im curious as to why you mounted the amp like that though... Aren't upside down mountings bad for the amp? Heat wise that is...
Curry is offline   Reply With Quote
Old 09-08-2007, 01:07 AM   #11 (permalink)
No problems so far,the stuff is coming out as soon as I take delivery of the 08 Camry LE.The 02 is getting traded in for it.
Old 09-08-2007, 01:20 AM   #12 (permalink)
MrSo0h0o's Avatar
what do u plan to do with the baffle u have made? if you arent using it, wanna give it up to me?
Old 09-08-2007, 01:53 AM   #13 (permalink)
I work in Queens,where about are u?
Old 09-08-2007, 08:56 AM   #14 (permalink)
MrSo0h0o's Avatar
i live in queens lol.. specifically bayside/whitestone/flushing area..
Old 09-09-2007, 11:38 PM   #15 (permalink)
View xjdmb16a2six's Photo Gallery
just wondering, how did you mount the wood under the rear deck? i've always wanted to do that but im scared that it would support the weight of my amps.
xjdmb16a2six is offline   Reply With Quote
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 02:37 AM
How to install front speakers on a 2002 Solara drewzmiller Solara 1 04-02-2007 12:31 AM
HORRIBLE exhaust install experience CDub LXi Camry & Solara Lounge 16 04-12-2005 01:55 PM
5sfe Engine Install xylium 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2005 03:07 AM
Attn: FLOWERMAN, heres your 2002 speaker install... Zeek321 5th & 6th Generation (2002-2006 & 2007-2011) 8 08-30-2002 10:59 PM
