ahh! sub worked great until i turned the car on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 07:57 AM   #1 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
im putting a sub into my camaro. im using the aweful stock head unit so i have to use a speaker line to RCA converter. there isnt a remote on for the headunit, so i had to tap into the "acc on" switched wire going to it. everything ran great after i hooked it up last night, but i never had the engine running. this morning when the engine is running and regardless of whether or not the radio is on or off, i get a constant "WHOW WHOW WHOW WHOW..." from the subs. the WHOWing doesnt relate to engine speed, its just a constant pattern.
HELP! ANY info would be greatly appreciated.
Old 09-05-2007, 08:03 AM   #2 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
get another HU
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 09-05-2007, 08:47 AM   #3 (permalink)
ghettosled's Avatar
i need to but dont have the money yet. the subs and amp were free from a buddy.
Old 09-05-2007, 09:45 AM   #4 (permalink)
ST184
View Rico's Photo Gallery
Basically the subs sound "WHOW WHOW WHOW WHOW..." and when you look at them they're just pulsating? From that, I believe that you're amp is fried.
Rico is offline   Reply With Quote
Old 09-05-2007, 09:52 AM   #5 (permalink)
View jdmay's Photo Gallery
My amp made a noise like that when I first got it. I just lowered the sensitivity on the amp and it worked.
jdmay is offline   Reply With Quote
Old 09-05-2007, 11:03 AM   #6 (permalink)
JayMax03's Avatar
what kind of HU, amp, and sub(s) do have?
Old 09-05-2007, 12:50 PM   #7 (permalink)
I have a Pioneer hu and an in-line converter becuase I only had one set of rca preouts. The amp is a 400 watt 4 ch Soundstream Picasso. No subs, the amp is driving my Pioneer 6x9s and 6 1/2s.
Old 09-05-2007, 03:37 PM   #8 (permalink)
ghettosled's Avatar
yeah, they pulsate and there is some noise that comes from it, but not much. could the amp be fried if everything works fine when the engine isnt running?
ill look into changing the sensitivity.
2 other things im considering (i dont know if im going down the right path) but i dont have the amp or subs in their final locations, so the extra wire is just coiled up. maybe since they are all touching there could be funky feedback? also, the speaker line to RCA converter is about 12 years old, could it be going bad and picking up a signal of some sort from the motor?
Old 09-05-2007, 03:47 PM   #9 (permalink)
I've heard that if the wires are too close the there can be a noise like you're having. The manual that came with my amp said to insulate each wire if the amp is making a whining noise. If its only doing when the car's on it might mean that the amp's not getting enough power because of all the other eletrical sytems in the car. That's just a guess though.
I found this at Crutchfield it might help:
Are you hearing engine noise?
Any amp installation can be prone to engine noise. You may hear a whining or clicking sound (its pitch will vary with engine speed). Since most noise problems come from a poor ground, always make sure your ground wire is connected firmly to bare metal in the event of a noise problem. You can also try isolating your amp from the chassis of your vehicle by mounting it on a board or using rubber grommets or feet; using a different brand of patch cables; or, only if all else fails, installing a noise suppressor (like PAC's ANS-80). The tricky part is figuring out which step or steps to take. Please read the rest of this section and try some of the simple tests.
Noise in the patch cables
Noise can be picked up by the RCA patch cables connecting your components. To test this, detach the cables from your amp. (Note: A small number of amplifiers mute themselves when patch cables are removed. To defeat the automatic mute, insert one side (left or right) of a spare patch cable into the amp's left and right input jacks.) Turn on your system and engine. If the noise is gone, reconnect the cables to the amp, and disconnect them from your receiver. If you hear the noise, your patch cables are definitely picking it up. Try re-routing them, taking care to separate them from your power cable by at least 18 inches. Also, newer cars may have a cable that provides power to computers and lights in the rear of the vehicle — make sure that your patch cables aren't too close to this cable.
New and plan on buying the next AE86 concept whatever it evolves into. Xanaduce Introduce Yourself Here 8 08-06-2007 10:21 PM
FS, 02 Benz Coupe Showcar joesc230 Vehicles 2 01-15-2007 09:32 AM
2007 Camry In-depth Consumer Review phenderson Camry Hybrid 0 08-09-2006 10:15 PM
my story 91RED3S Off Topic 8 01-30-2005 04:55 PM
