93 camry speaker help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2003, 10:54 PM   #1 (permalink)
View celica/camry's Photo Gallery
ok....one of my factory rear speakers cracked so i replaced em with sum 200 watt 3way jensen speakers i had layin around
can anyone tell me an afordable speaker that will have as much bass as the old speakers
the rest of the system is stock....also i was told to go only up to 50 or 75watt speaker on the stock hu
"i got a toy on sum alloys boy"
celica/camry is offline   Reply With Quote
Old 08-25-2003, 10:57 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Infinity Reference speakers are great and won't break your budget but I don't think they fit into your wattage range. They should sound fine though even though they're powered off the headunit, just can't get too too loud.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 08-26-2003, 03:48 PM   #3 (permalink)
confrontations of image
Structureboy's Avatar
View Structureboy's Photo Gallery
Well, factory speakers really never had so much *oomph* to begin with so I imagine any aftermarket speaker will have plenty bass. infinity's, jbl's, anything from the haman corp. is great stuff.
Look for some speakers with good RMS power range. Ideally, running off the HU, you woud like the minimum power to be as low as possible. Don't be too concerned about distorting your speakers if you run it just off the stock headunit. I did that for awhile on my cam, powering some 6.5 JBLs. As long as you don't listen to music insanely loud, you should be fine.
check out www.crutchfield.com for some good deals
#39 Goalie for Baylor Ice Hockey Team
"life for him was an adventure, perilous indeed, but men are not made for safe havens."-Edith Hamilton
Visit:
www.emdef.org
|>Keep electronic music in our clubs<|
Structureboy is offline   Reply With Quote
Old 08-26-2003, 11:09 PM   #4 (permalink)
what would be a good rms?
Old 08-26-2003, 11:12 PM   #5 (permalink)
would those...OEM speakers that the sell in walmart, discount audo parts and other part stores be ok?
they are 4 ohm 50-75watts dunno the rms
but the old ones were 25 watts and 6 ohm
Old 08-27-2003, 12:25 PM   #6 (permalink)
Would you buy a 2004 toyota from a salvage lot? No.
They're not OEM original equipment of manufacturer speakers if they sell them at walmart.
Speakers from walmart- Are they Sony's? I bet they're Sony's, or probably Jensens- are probably not very good. Walmart usually doesn't come to mind for audio goodness.
Check out ur circuit city for lower-midpriced stuff or your audophiles guru store for higher-end stuff like eclipse, mb quart.
A decently good range would be like...2 watts-whatever...letsa say...80. 2-80 watts RMS
Since you're only running off your HU, shouldn't be too concerned about the higher value I think. But just in case, later in the future, you decide to add some ampage to your system it'll be nice if your speakers can hold up to more pwr.
Visit:
www.emdef.org
Old 08-27-2003, 12:31 PM   #7 (permalink)
some glossary terms
RMS- is amount of power that a speaker can handle under a continual basis.
the maximum watts- is the total amount of power a speaker can handle in an instance. pay no attention to this value when looking for speakers.
Don't you ever frequent the audio forums?
Visit:
www.emdef.org
Old 08-28-2003, 02:26 PM   #8 (permalink)
found out what my prob was...the EQ was set to much toward the front....now i set it on 40% front and 60% rear
i also fount sum new 25 watt rms 60 max rms speakers new cost 20...the actally dont sound that bad...they are clearer than stock
