Security/Alarm questions...
hey guys, i just recently installed a Viper 650XV with an ignition cutoff tied into the rear driver side power button.. the only way you can start the car is you must pull the rear driver side window button up while you turn the key...
now i have a few questions to help strengthen the security on this car... its a 92' Toyota Camry LE(as it says in my sig).. the guy that installed my alarm system said theres an optional secondary battery that you can hook up to the alarm system incase the thief disconnects the battery... now if someone is trying to steal the car, they break the window, and pop the hood.. wouldnt they go for the siren and yank out the wires, essentially making the 2nd battery useless? or do they go for the battery first.. because the siren itself is mounted on the driver side firewall in the engine bay, clearly visible...
also, has anyone tried disconnecting their hood release cable as a security measure? and if so, how hard is it climbing under the front bumper to get it to release manually?
92 Camry LE 5SFE
35% tints all around | Viper 650XV/w remote start
Cleared bumpers | Sylvania Silver Stars
Whiteline rear anti-sway bar
Compaholics.com
