Need Some Help With Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2003, 01:26 PM   #1 (permalink)
Rice Eater!
View RiCebuRneR206's Photo Gallery
Question Need Some Help With Wiring
I have 2 MTX subs. Both have only 1 4ohm voice coil. I was wondering how do i wiring them to run at 4ohms? If I can't do that, how can i run them at 2 ohms? I am hooking them up to a Rockford Fosgate 250a2 and it makes more power bridged at 4 ohms. Any info would be great! Thanks.
1995 5spd Camry *SOLD*
1995 5spd Integra LS
BONE Stock and Lovin' It
RiCebuRneR206 is offline   Reply With Quote
Old 08-30-2003, 06:41 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
You will never be able to run 2 4-ohm subs @ 4-ohm when there is only a single voice coil on each. You are left with a 2-ohm load (parallel), or 8-ohm load (series). Check whether the RF amp can handle 2-ohm mono, since that translates to 1-ohm stereo. My guess is that it probably will be able to run them, albeit, a bit warmer. Just make sure there is good ventilation.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-31-2003, 10:57 AM   #3 (permalink)
Rice Eater!
I'm pretty sure the amp can handle 2ohms but not bridged at 2 ohms. Right now the way i have it hooked up is each speaker is connected to its own terminals. Then from the terminals i hooked up positive from both sides to each other and negatives to each other. So the 4 wires merge into 2. Then i plugged them into the amp. I dunno if that's right but the RF is way too damn powerful for the subs. They hit so hard with the bass boost down all the way.
Old 08-31-2003, 01:21 PM   #4 (permalink)
Luc
What you have wired up is 2-ohm stereo, which is the same as 4-ohm mono. In the past, RF amps have been able to run 2-ohm mono, though it isn't recommended by them. You can always turn the gain down since the subs are too loud for the rest of the speakers.
