Need Amp Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2003, 12:21 AM   #1 (permalink)
View Skylinegtrvspec's Photo Gallery
Need Amp Help
My amp shuts down when i raise the gain high or the volume on my deck high and i don't know why. I have 4 gauge wire for the ground and the amp is only rated at 280watt rms whereas im using it to push a 700watt rms sub...is it maybe becuase its not getting enough power or what? Any help would be appreciated.
Trev
Edit: I don't ever max out the gain on the amp or the volume on the deck.
Skylinegtrvspec is offline   Reply With Quote
Old 08-30-2003, 01:38 AM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
assuming you really don't dial up your gain to the max...make sure you've got a solid ground connection (ie. mating surfaces are free of paint).
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 08-30-2003, 01:43 AM   #3 (permalink)
surfaces have been completely sanded and are free of paint...my car has the stock alternator so its 14 years old..maybe its going to die soon?
Old 08-30-2003, 07:20 AM   #4 (permalink)
The terrorist
View Xenon's Photo Gallery
It seems like your Amp is not getting the power is needs to operate on higher wattage, check your Alternator, battery and power connections..
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 08-30-2003, 07:15 PM   #5 (permalink)
how can i check my alternator and my battery? my connections are fine. thanks for the help so far guys.
Old 08-31-2003, 01:27 PM   #6 (permalink)
Luc
View Luc's Photo Gallery
Re: Need Amp Help
Do you have 4-gauge for power also? You didn't state it. If not, definitely use the same gauge for power and ground. You shouldn't have to use 4-gauge for a 280-W amp, 8-gauge should be plenty. The conductivity of the power cable may have deteriorated also, so you can try and replace that, since it'd be cheaper compared to replacing battery and/or alternator.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-31-2003, 01:48 PM   #7 (permalink)
View prophesized's Photo Gallery
are your subs wired to give an impedance your amp cant handle?
prophesized is offline   Reply With Quote
Old 08-31-2003, 04:39 PM   #8 (permalink)
My power wire is 8 gauge but it would cost me about 100$ to replace it with 4 gauge. It should also be in very good condition considering i just bought it a month ago. The amp is made for 2 and 4 ohm loads so it should be fine. My sub is wired for 2 ohms i believe but im not sure??? If you need info bout the sub its an Audiobahn AW1200Q sub.
Old 08-31-2003, 11:03 PM   #9 (permalink)
Luc
You should definitely use 4-gauge power, or 8-gauge ground. The current is sinking faster due to the 4-gauge ground, and not enough sourcing due to the 8-gauge power cable. It should not cost you $100 to swap to 4-gauge power, since they typically run about $2/ft. If you get about 16 ft, that's only $32. You can also get something like the Monster Cable 500-W amp kit, which includes 4-gauge power & ground, remote turn on, etc., all other parts needed to completely run an amp, for about $70.
Old 08-31-2003, 11:31 PM   #10 (permalink)
where i live 8 gauge runs for 2$ a foot and 4 gauge runs for 5$ a foot...i need 20 feet of it...thers my 100$. as for the having power sinking problem it happened b4 i upgraded the ground as well so its not that.
Old 09-01-2003, 12:31 AM   #11 (permalink)
Luc
Doh! I was thinking in US funds.
It still sounds like the 8-gauge power isn't getting enough current to the amp. My friend had a similar situation in his (bigger) amp, JL 500/1, his 8-gauge power couldn't handle the current flow. Once he switched to 4-gauge power & ground, all is well. He even told me his 8-gauge melted, afterwards.
Old 09-01-2003, 12:40 AM   #12 (permalink)
ok well my 8 gauge is only carrying a max of 500 watts or so i think...so it should be fine. If i have that problem after i get a cap and a battery maybe ill upgrade...if you can think of anything else it could be let me know!
Old 09-01-2003, 01:36 AM   #13 (permalink)
or you can buy 4 awg online for 99 cents per foot
http://www.knukonceptz.com/search_re...btnSearch.y=10
Old 09-01-2003, 02:03 PM   #14 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
wouldn't trust that stuff.....good 4 gauge costs more than that anywhere.....probably not very good shielding on that stuff....
HaHa
Old 09-01-2003, 04:38 PM   #15 (permalink)
just because wire costs alot does not make it the best. i run nothing but knukonceptz wiring in my car. ive used the same 15 foot run of 1/0 gauge for at least a year and a half. aside from flexability, you probably couldnt find a difference between that and monster or stinger wires.
