Burned Voice Coil (audiobahn) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2003, 02:00 PM   #1 (permalink)
View oibone781's Photo Gallery
Does anyone know where i can get info on fixing a burned VC..?
oibone781 is offline   Reply With Quote
Old 08-30-2003, 06:21 PM   #2 (permalink)
View prophesized's Photo Gallery
get a recone from audiobahn
prophesized is offline   Reply With Quote
Old 08-30-2003, 06:36 PM   #3 (permalink)
Luc
View Luc's Photo Gallery
He has a burnt voice coil, not a split in the rubber surround, the two are totally different.
Unfortunately, "fixing" a voice coil isn't something that's easily done since it's the copper wires that need to be replaced. You should contact Audiobahn directly and go from there.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-31-2003, 01:46 PM   #4 (permalink)
they are different but can be fixed the same way. a recone changes all moving parts in a sub which includes the vc.
Old 08-31-2003, 06:18 PM   #5 (permalink)
And where can i get a recone
Old 08-31-2003, 06:19 PM   #6 (permalink)
Is there any place that sells just the voice coil, i took everything out of the frame and it's still in tack, all i need is the voice coil...if i would have played it any longer it would have caught fire...
Old 08-31-2003, 07:11 PM   #7 (permalink)
you cant just buy a vc and put it in there because it has to be perfectly centered in the gap. sending it in to audiobahn is your only choice if you want to keep that sub.
Old 08-31-2003, 07:38 PM   #8 (permalink)
I got the speaker off of ebay, do u think they will still take it, if not do u know anywhere that sells recone kits
Old 08-31-2003, 08:09 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You sure you didnt play it with an amp too small powerwise? That easily burns out the voicecoil as when it starts clipping it would make the voice coil heat up and fast.
Old 08-31-2003, 08:26 PM   #10 (permalink)
all i know is that the voice coil is burned, i need a recone kit, i can do the job myself,, if i bought the speaker already blown for 20 bucks,thinking i can fix it,, will audiobahn take it...
Old 08-31-2003, 08:36 PM   #11 (permalink)
they will take it but you will have to pay
Old 08-31-2003, 09:01 PM   #12 (permalink)
hopefully it isnt t0 much
Old 08-31-2003, 09:48 PM   #13 (permalink)
recones are usually around 100 before shipping
