Can i upgrade / add sub to oem jbl nav dash?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2007, 11:37 PM   #1 (permalink)
View tkkidd's Photo Gallery
Gen5 Can i upgrade / add sub to oem jbl nav dash??
i love my oem navigation system.
2002 camry se jbl head unit.
but i hate my speakers... base is so weak...
is it possible to add sub? change speaker??
i do not know nothing about car audio.
i bow in advance to your audio jedi power.
tkkidd is offline   Reply With Quote
Old 09-23-2007, 12:30 AM   #2 (permalink)
View thoughthard's Photo Gallery
Yes, you can add a sub.
There are so many ways to do it...
thoughthard is offline   Reply With Quote
Old 10-08-2007, 10:38 PM   #3 (permalink)
TRDSleeper's Avatar
View TRDSleeper's Photo Gallery
You can do lots of things to upgrade your car audio system. I started out with absolutely no knowledge whatsoever. I learned by going on various forums and websites. Crutchfield.com has a special advisor page that explains a lot of car audio concepts to newbies. I learned most of my knowledge from them.
I started building my system by switching the factory speakers to aftermarket speakers. If you get the correct size speakers then they should fit with no modifications needed. Just simply mount them in the factory openings with the screws provided with the speakers. Sometimes you might need to drill new holes but Crutchfield can tell you if you need to or not. Aftermarket speakers provide a tremendous difference in sound quality than stock speakers.
After you swap the speakers, you can choose to get an amplifier or subwoofer later on (when you have gained more knowledge about car audio). Good luck.
TRDSleeper is offline   Reply With Quote
If my Camry's OEM glass is 70%(visible light), what happens when I add 50% tint? bluemoose 5th & 6th Generation (2002-2006 & 2007-2011) 5 07-16-2007 05:45 PM
OEM Factory keyless alarm upgrade, anyone? robstaco 2nd Generation (2005+) 0 11-27-2006 03:05 PM
