Originally Posted by built2burn
if i have a amp that produces 150rms per chan @ 4ohms, would it be a bad idea to use speakers that have 60rms @ 4ohms?
the amp is also used by my sub would running those speakers have an effect on my subs?
thanks
How many channels does your amp have? How many channels are you using for the speakers and for the sub?
If you have a 3-5 channel amp and are using 2 for speakers and the extra for a sub, then nothing will be affected except for the amp getting hotter. If there is not enough ventilation then it might overheat, that's about the only affect.
The amp will be fine for those speakers as long as you set the gains properly and have a crossover keeping the right signal going to them. And don't turn them up until they bleed.
