DIY Alarm Install on a 3rd gen? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2003, 06:14 PM   #1 (permalink)
Crossdrilled and Slotted
View myconid's Photo Gallery
Does anyone have experience with installing their own alarm on a 3rd gen? I have an electronics background (4th year of my Bachelors of Computer Engineering), but I was supprised to see the wiring mess behind my glove box. Wow toyota. Way to cram 3000 ft of wiring into my dash .
I was curious if someone would be willing to give me a hand here finding the ignition wires.. I have not gone as far as ripping the top part of my dash off to find out where the wires go from the actual switch, but I have found the relay block and such.
I also need pointers on where to hook up the other leads. Thanks.
myconid is offline   Reply With Quote
Old 09-01-2003, 06:21 PM   #2 (permalink)
View fatrabbit's Photo Gallery
http://www.bulldogsecurity.com/New%2...toyotindex.htm
fatrabbit is offline   Reply With Quote
Old 09-01-2003, 06:49 PM   #3 (permalink)
Aw yea.. Getting there.
Anyone know specifically what the ignition harness looks like, or where I can find it. It seems pretty tight on the drivers side.
Old 09-01-2003, 10:53 PM   #4 (permalink)
Luc
View Luc's Photo Gallery
Better leave the job to an EE instead.
If you remove the steering column, you will find the ignition, accessory, and constant 12V wire harness, all are 12-gauge wires, you can't miss it. What you see behind the glovebox are wire bundles to/from the ECU, I'd leave that alone unless the wiring identification says it needs to be tapped there. Most wires are located near the driver's kick panel. You may need to diode isolate the two lock wires, one for regular lock, one for child safety.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 09-01-2003, 11:17 PM   #5 (permalink)
Group Buy Junkie
View jhale1's Photo Gallery
I've installed an Alarm & Remote Start on mine, and already have the lower part of the dash apart anyway, so if no one relies before then, I'll take a picture for ya and post it tomorrow.
BTW: I spent a year in college doing Electrical Engineering, and another year doing Computer Networking....
jhale1 is offline   Reply With Quote
Old 09-03-2003, 01:04 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Heres a wiring diagram that i've scanned:
The wiring diagram says 1995 Camry, but the wiring is the same for all gen 3's. So ignore the 1995.
The wires listed for the door lock / unlock is wrong. I forget which one is wrong, but one of them is wrong. So use a dmm to find the right wire.
Disclaimer: Wiring diagram is only for information. What you do with it is your problem. If your car catches on fire, etc.... due to your ignorance about car electrical systems its your fault.
"Skoolin' the unlearned!"
