rms and max power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2003, 10:26 PM   #1 (permalink)
View MYCARcamry's Photo Gallery
Unhappy rms and max power
hey i need help i have two 15 inch power pro pyramid subs, it has the power handling of up to 700 watts each but says 325 watts rms if i go over the rms limit but under the peak power handling would it blow out the subs ???
MYCARcamry is offline   Reply With Quote
Old 09-02-2003, 11:17 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
No, you will not blow your subs. The max power listing is only for sudden burst, and isn't meant to be fed that much of power continuously. Even if you get a more powerful amp, you can turn the gain down.
In theory, MAX = square root of 2 * RMS, but manufacturer typically list more for advertising purposes.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 09-02-2003, 11:54 PM   #3 (permalink)
View prophesized's Photo Gallery
yeah dont even bother looking at max ratings...only rms is important. id be careful giving those subs 325 watts though.
prophesized is offline   Reply With Quote
Old 09-03-2003, 01:42 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Its better to have a too powerful amp than too little. Going over the speakers power rating wont burn it, it'll distort. BUT if you go too little it'll start clipping and when it clips, air isnt moving in the voicecoil so it will only heat up and burn. So you'd be safe with an "overpowered" amp.
Old 09-03-2003, 01:44 AM   #5 (permalink)
so you think i should get an amp that has 1400 watts by 2 chan?
Old 09-03-2003, 02:17 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Well why do you want an amp that big for those subs?
Old 09-03-2003, 04:46 PM   #7 (permalink)
to set off some alarms and shake house windows duhhhhhh!!!!!!
Old 09-03-2003, 06:22 PM   #8 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
well you better get some new subs and learn to build boxes and a ton of other stuff.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 09-03-2003, 06:31 PM   #9 (permalink)
yo i have 3 toyota's
aladdin102's Avatar
View aladdin102's Photo Gallery
sorry to break it to u bud but pyramid subs aint the brand i would use to set off some alarms
aladdin102 is offline   Reply With Quote
Old 09-03-2003, 09:47 PM   #10 (permalink)
clipping doesnt blow subs and for those subs i would just get like a 500-600 watt mono amp.
Old 09-04-2003, 05:11 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Clipping prevents the voice coil from moving which pumps air into the cavity built into the voice coil housing. Then the voice coil starts to heat up, and if the coil heats up, it can burn.
You can make windows shake and car alarms sound with a 10" with a proper box.
Old 09-04-2003, 12:43 PM   #12 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
tip: do not run 1200watts thru two subs rated at 150rms.... :p
HaHa
Old 09-04-2003, 02:37 PM   #13 (permalink)
HEY THANKS ALOT FOR THE ADVICE OK THEN WHAT KINDS OF SUBS WOULD YOU RECOMEND FOR ME TO GET TO CRACK THE PAVEMENTS ?? (JUST A PHRASE) HOW MANY WATTS WOULD YOU RECOMEND ME TO GET TO PUSH ONE OF THE SUBS AND HOW ABOUT TWO OF THEM
Old 09-04-2003, 02:41 PM   #14 (permalink)
aladdin102's Avatar
watch ur caps guy and i recommend 1,000,000 watts for car audio that way u can be the loudest thing ever created
Old 09-04-2003, 02:42 PM   #15 (permalink)
Stealth's Avatar
2 subs are barely louder than 1 sub so you might as well get like a 15 or 18 and give it a ton of juice. look into adire brahma's or digital designs subs if you got the money
