Jack up your driver's side wheel and take it off. Remove the fender splash gaurd and you should see a hole from there that goes to the engine bay. Put the wire through there and then you should see another wire that goes through this rubber grommet. You need to cut a hole in it and it should come out behind the driver's side kick panel thingie, next to the dead pedal. Then you can just hide the wire along the side of the car under the carpet.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
