2000 Corolla mp3 player hardwire help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2007, 11:27 AM   #1 (permalink)
View ltgriseau's Photo Gallery
I have a 2000 Corolla with stock stereo headunit(has cassette) with a stock Toyota single disc CD player mounted at the bottom of the center console.
Would it be possible to splice into the CD player speaker wires with an 1/8" stereo adapter for my mp3 player and keep the CD player for use at other times?
I don't think the headunit has an additional AUX input.
ltgriseau is offline   Reply With Quote
Old 10-07-2007, 10:37 PM   #2 (permalink)
View yota83's Photo Gallery
no.....speaker wire are outputs (signal goes from radio OUT to the speakers)
for an mp3 player you must INPUT the song from the mp3 player to the radio then to the speakers....
if your stock radio has no inputs (i.e. stock cd changer or aux port etc.) then you cant hook it up unless you put an aftermarket radio in with the necessary hookups....
yota83 is offline   Reply With Quote
Old 06-30-2009, 05:33 AM   #3 (permalink)
View tblo163's Photo Gallery
UK Mp3 Playback.
I realise this post is probably too late to help you,you've obviously had 2 years to sort it.However I have just posted details on how to playback MP3s on a cassette deck.It's titled POOR MANS MP3 PLAYER. Any help I can give is allways available Terry
tblo163 is offline   Reply With Quote
Old 07-13-2009, 08:48 AM   #4 (permalink)
View AKADriver's Photo Gallery
yota83's reply was wrong anyway; you can absolutely splice in to the CD player wiring, which is in fact an input to the head unit.
In order to play MP3s you'd need to have a "silent CD" in the player, I believe.
AKADriver is offline   Reply With Quote
Old 07-13-2009, 11:15 AM   #5 (permalink)
mp3 play-back
tblo@o2.co.uk
The instructions I gave were for mp3 play back using a CASSETTE Player not a CD/Player.As I said previously,mp3 play-back is a matter of simply splicing into the 3 pick-up wires & using an empty cassette as a switch.A toyota CD/Player is an entirely different project,you must splice into the pick-up between the pick-up head and the IC Before the pre-amp,(this involves removing the CD-carrier to access the circuit board)this is NOT an easy task,& should not be attempted unless you are confident that you can do it:Even when you have done this,you still have to tell the unit to play,a silent CD Disc will NOT work,neither will a blank CD or data disc,the player will eject them after loading,(you can fool the cd into loading by inserting ANYTHING into the cd slot)but it still will not play.to acheive a playback you have to go back to the circuit board and install by-passes to the motors that control loading and play-back.or the existing switches in the carrier.From past experience I find that all this work not worth the effort.My alternative is to build a stereo amp and play-back via the car's speakers.I've built an amp using two TDA 2003 ICs,the sound quality is exellent,and it does not need a pre-amp.Any one needing diagram for this amplifier,just ask.in the mean time I've uploaded the full pdf(56mb)of the Toyota cd/radio,you will see what you are up against GOOD LUCK TERRY. Sorry can't find the attatchment link.please help.
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
MP3 Player AND Cassette Player? underpowered Audio, Video, and Security - Tech 7 07-10-2006 05:55 PM
Can I connect my mp3 player to speakers direct? breadbin Audio, Video, and Security - Tech 1 07-01-2006 04:40 PM
MP3 Player Bakemono Off Topic 11 06-22-2006 12:25 AM
