Help with grounding Gen4 Cam - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2007, 01:12 AM   #1 (permalink)
View built2burn's Photo Gallery
4th Generation Help with grounding Gen4 Cam
Where is the best place to ground an amp that is in the trunk.
A pic would be best
Thank You
built2burn is offline   Reply With Quote
Old 10-03-2007, 01:47 AM   #2 (permalink)
xet
View xet's Photo Gallery
seatbelt bolt, I used the side cushion bolt but I had to cut away at the plastic
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 10-03-2007, 09:50 AM   #3 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
A pic would be best
Thank You
Pull up some of the trunk carpet where the seat meets the trunk sand and drill the floor. Make sure your gas tank isnt in the way.
Also make sure to keep your ground under 8 inches long.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 10-03-2007, 10:07 AM   #4 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
To took the back seat out of my Gen3 and drilled a 5 inch nickel-plated screw 2 inches away from the seat belt. Gen4s should be the same way I think?
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
new here, here are pics of my gen4 cam gen4drft Show & Share 28 08-19-2006 04:36 PM
1MZ Cam marks won't align dgspencer Camry & Solara Lounge 5 03-15-2006 08:32 PM
Avalon rear disc brake fit on a gen4 cam? RED171 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-30-2005 08:47 AM
anyone install a oil pressure gauge on a gen4 cam? LiLItalian 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-22-2004 07:16 PM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
