Subwoofer Install in SR5 Dual Cab - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2007, 03:49 AM   #1 (permalink)
View DigitalSI's Photo Gallery
Australia Subwoofer Install in SR5 Dual Cab
Has anyone ever had a subwoofer installation on a Hilux SR5 Dual Cab?
If so, could you please let me know what you used and where the sub/s were fitted?
I think the only two fitting options are either behind the rear seat or under the rear seat and i guess a slimline sub is the only option too. Really appreciate anyones feedback.
Thanks in advance
Karlos
DigitalSI is offline   Reply With Quote
Old 10-08-2007, 02:13 PM   #2 (permalink)
View yota83's Photo Gallery
i had a slim 12" sub behind my seat in my reg. cab and it worked good....also had 2 speakers in doors and 2 in the kick panel area on a 4 channel amp...it sounded pretty good for a little reg. cab.
my guess would be a 8" or a slim 12" sub would probably fit under or behind the rear seat.....
yota83 is offline   Reply With Quote
Old 10-08-2007, 06:51 PM   #3 (permalink)
8" Slimline Sub's
Thanks for the info.
I think I will install two Earthquake SWS-8 8" Slimline Subs or Pioneer TS-SW841D 8" Slimline Subs under the rear seat connected to an Alpine PDX-4150 4CH amp. I just can't decide between the Earthquake single voice coil or the Pioneer dual cone, if anyone has a recomendation, please let me know.
Earthquake weblink: http://www.earthquakesound.com/sws.htm
Pioneer weblink: http://www.pioneer.com.au/products/c...nge/index.html
Alpine weblink: http://www.alpine.com.au/products/pr...sp?modelID=263
Karlos.
Old 10-08-2007, 11:17 PM   #4 (permalink)
View chemop2's Photo Gallery
I personally prefer pioneer but either one will work on that amp just make sure you set your gains appropriately.If you need box ideas this should help with dimensions. http://www.supercrewsound.com/shop/cat/93.htm
chemop2 is offline   Reply With Quote
Old 10-09-2007, 12:04 AM   #5 (permalink)
Thanks for the info, im going to measure the area behind the seat to see if it the twin hole rear seat enclosure on the website you gave me will fit in my truck which is the Australian version of the Tacoma. I hope it is the same as i really like the idea of a professional enclosure over making a custom enclosure.
I am going to connect my front speakers to the Alpine 4150 on CH 1 & 2 @ 4ohm. The rear speakers i am going to connect directly to the head unit.
I will then use CH 3 & 4 to connect to two subs but i have been told to wire these as 2ohm.
To wire these as 2ohm, would you wire them in series or parallel?
Old 10-09-2007, 12:30 AM   #6 (permalink)
PDX amps produce the same amount of power into both 2ohm and 4ohm so just hook each sub to its own channel and your good to go.
Old 10-09-2007, 03:48 AM   #7 (permalink)
Australia
Thanks so much you have been a really great help and i appreciate your feedback.
Karlos
Old 10-09-2007, 10:26 AM   #8 (permalink)
just make sure you set your lp filter on channels 3 and 4 and your hp filter on channels 1 and 2 so you seperate your lows and highs to the correct speakers....
good luck with the install!
2006 Toyota Tacoma 4x4 SR5 access cab, PA/NJ, 4k miles, 5spd, leer cap, $22k Turbost Vehicles 0 02-20-2007 03:31 PM
2007 Tundra prices listed @ www.toyota.com BEI Toyota News 22 01-26-2007 01:09 PM
echo hatchback subwoofer install? TOrolla Yaris, Vitz and Echo Forum 9 10-27-2004 05:07 PM
SR5 oil and Volt guage install..need help cray_ze Archived Corolla threads 1 12-13-2003 05:25 PM
Dual Exhaust install importfest Camry & Solara Lounge 30 08-31-2003 10:36 AM
