way to test amp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2007, 11:45 AM   #1 (permalink)
WHAT???
View supra06's Photo Gallery
way to test amp?
my amp was working and took it out to put it in the new car and been sitting their for 1 month and now i dont know if its the amp or the installation. what could possibly be wrong with it? its in a 98 avalon and i havent scrape the paint off where i mounted the ground, could this be the problem? it also blinks and then shuts off when i turn the HU on
supra06 is offline   Reply With Quote
Old 10-08-2007, 11:48 AM   #2 (permalink)
PDR Tech
feliks's Avatar
View feliks's Photo Gallery
Lol yeah, it's your ground
feliks is offline   Reply With Quote
Old 10-08-2007, 11:48 AM   #3 (permalink)
PDR Tech
feliks's Avatar
I'd say it blinks because it carried enough of a load for the led to come on but as soon as it draws current the ground isn't good enough to handle it....clean up the ground and it should work.
Old 10-08-2007, 11:50 AM   #4 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
You heard the man. I have a love hate relationship with electronics
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 10-08-2007, 02:33 PM   #5 (permalink)
WHAT???
thanks guys for all the responses, will try that today.
thanks.
Old 10-08-2007, 06:19 PM   #6 (permalink)
WHAT???
i scraped the paint off, it still does the same thing what could be the problem?
Old 10-08-2007, 07:17 PM   #7 (permalink)
View thoughthard's Photo Gallery
It sounds like it is protection mode.
The ground would work through the paint. You scrape off the paint to get a "better" ground.
thoughthard is offline   Reply With Quote
Old 10-08-2007, 08:00 PM   #8 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
check the remote wire to see if its any good it could have a break or short in it
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 10-08-2007, 10:18 PM   #9 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
take your remote off and connect your PWR cable and your GND. Then take a little wire and connect it from the PWR to the Remote. Check to see if it turns on, it should turn on right when you connet the jumper wire from the pwr to the remote. If iut works than you might have a prob with your remote wire. And dont use this as a solution because your amp will stay on constanty unless you take the constant 12v away fro mthe remote. i hope i make sense. If this doesnt work im not sure, try hooking the amp up to a buddys car
CamrySExxx is offline   Reply With Quote
Old 10-08-2007, 11:50 PM   #10 (permalink)
WHAT???
will try this 2morow, thanks again guys
Old 10-09-2007, 02:58 PM   #11 (permalink)
ST184
View Rico's Photo Gallery
Lightbulb
What's the location of the ground?
What's the current draw on the amp?
The location of the ground is also important. Be sure to have plenty of metal to be grounded at. I had a case where a customer grounded their MTX 8001 amp to the thin sheet metal that is hidden behind the passenger seats - the amp fried itself. If it's a 'big' (powerful) amp, ground it at your seatbelt anchors. Unbolt the seatbelt buckle and attach your ground there.
Let me know if that helps.
Rico
Rico is offline   Reply With Quote
Old 10-09-2007, 10:17 PM   #12 (permalink)
WHAT???
got it to work, their is something wrong with the remote wire on the HU, because i have it plugged into the fuse box by the drivers side door, it turns off and on with the key turned to on, so it works perfectly now, what could be causing the remote wire on the HU to not work properly?
Old 10-10-2007, 08:12 PM   #13 (permalink)
bad wiring ?
Old 10-18-2007, 05:25 PM   #14 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
for the remote wire all you need is a power wire that turns on when the radio turns on... anything will work if there is a problem
tHa kNiGHt FaLL is offline   Reply With Quote
Help with amp please built2burn Audio, Video, and Security - Tech 1 09-11-2007 07:31 AM
Please help camry amp install help Camryv6xle Audio, Video, and Security - Tech 2 08-12-2007 03:04 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
Do I Even Need My Amp? Durrby Audio, Video, and Security - Tech 19 01-07-2005 05:59 PM
What amp kit for Rockford 500X amp Eniffey Audio, Video, and Security - Tech 3 05-16-2003 11:14 PM
