memory amp wire? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2003, 01:08 PM   #1 (permalink)
View MagicOne's Photo Gallery
Question memory amp wire?
i just got a new audiobahn amp to put in my camry but i cant seem to find which wire is the remote/memory wire. ive seen the chart and went through the searches and all that but i still cant seem to find the correct wire. i did find a white wire that turns the amp on when the ignition is on but it gives feedback when the radio is off and the gain is turned up almost half way. i am trying to put this into a 98 camry LE with factory installed tape/cd player with 6 speaker setup. any help with this would be appreciated.
MagicOne is offline   Reply With Quote
Old 09-09-2003, 08:41 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
where did you hook the remote lead from the amp to?
HaHa
Old 09-09-2003, 10:02 PM   #3 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Sounds like he may have hooked it up to the power antenna wire? I think the remote turn on wire is blue with a white stripe? I'm sure it's blue.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 09-09-2003, 11:04 PM   #4 (permalink)
TN Pussy Man
hmmm.....but why would it give feedback then? strange....maybe the wiring's wacked and the signal wires are run down the car along with the power wire that doesnt' have enough shielding?
HaHa
Old 09-09-2003, 11:08 PM   #5 (permalink)
well i couldnt find a blue wire with a white stripe...just a solid blue one.....ill play around with the wires some more...some of the wires im told to look for i just dont see the color combos or when i do connect it it does nothing...another solution i guess is to hook it to the ignition wire itself but i was trying to avoid all that...i know nothing of ignition systems.
Old 09-09-2003, 11:41 PM   #6 (permalink)
ok i found 3 total wires that even remotely do anything with the amplifier. solid red wire turns amp on but amp sends no signals to speaker. solid white one turns amp on totally but gives feedback when radio is off and gain on amp at half way . solid black one right next to the white one does the same. i did find a solid white wire with a blue stripe (that does nothing) but no blue with white. this seems to be the only wire with a stripe. all others are solid.
Old 09-10-2003, 03:01 AM   #7 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
use the power antenna wire!!!! definitely...
you DO NOT want to hook up a power wire with high current (Amps). the amp remote wire is a low current 12 Volt source which only switches a relay for the high current power... the power antenna wire works, its been done millions of times not only in camrys... i did it on my girl's old cavalier, and her new 2001 celica gts...
the power antenna wire is perfect for this, because it is just what the amp is looking for... a low current 12V source.
why do they keep moving posts which are model specific into the audio forum!!!!! i hate this!!! people need specific information on their model!!! stop moving threads even though they have SOMETHING to do with audip, they still are more about the specific model!
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-10-2003, 04:53 PM   #8 (permalink)
Call me DR. DIY or SHGUN
View Bigshoguns's Photo Gallery
HMMMMMMMMMMMMMMM
HMMMMMMMMMMMMMMM
I think the whole problem is taht ur tring to hook it up to ur Stock tape/cd player. remeber stock wont have a remote wire only Aftermarket HU's.
but if for watever the reason u wanna use stock then i suggest buying a relay or a on/off switch to turn ur amp on.
BTW i have a 98 le and i had it hooked up to my stock hu too, but i used a relay. so if u need more help shoot me a IM or Email or PM. but now i got a ALpine HU so now i use the remote turn on..
hope this helped.
Bigshoguns is offline   Reply With Quote
Old 09-10-2003, 08:54 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
USE THE POWER ANTENNA WIRE!!!!!!! nothing else!
Dave Zoni
Old 09-10-2003, 09:13 PM   #10 (permalink)
Luc
View Luc's Photo Gallery
He has a Gen4, with the antenna leads in the rear window, so there is NO, repeat, NO power antenna wire in the harness, unlike the Gen3.
First off, since you have the premium system, it's the OEM amp that powers the headunit!! That red wire you found should be the turn-on to the factory amp. The white wire is the radio accessory. The black is the power lead from the amp to the radio. Not sure what that white/blue wire is.
Thus, the red wire should be tapped in, and most likely, you will need to wire up a relay to trigger the remote turn-on on the Audiobahn amp.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 09-11-2003, 06:48 AM   #11 (permalink)
well all this info is helping me to get a better understanding of the camry radio wireing system....thanx. i would buy an aftermarket radio and end all this madness if it werent for "window shoppers", so i guess ill just have to go the relay route. and also luc is right....my ant. is in my rear window.
Old 09-15-2003, 03:27 PM   #12 (permalink)
finally got it connected yesterday...i called both the auto parts stores and the audio stores and both didnt know what i was talkin about.....so i spliced it into the cigarette lighter power wire. works great now....and thats a lotta power commin out for just a little 10' sub
