1997 Camry LE Just need someone to give me step in the right direction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2007, 09:46 AM   #1 (permalink)
View Tru NYY Fan's Photo Gallery
I have a 1997 Camry LE and was wondering if I installed these things
front
http://www.crutchfield.com/S-47G2WFV...SPS17C2&tp=105
rear
http://www.crutchfield.com/S-r745dZ0...speakers&tp=91
deck
http://www.crutchfield.com/S-Oehb4j9...90&c=3&tp=5684
would I need a aftermarket amp or could I just use the amp that came with the car. From what I understand the amp is under the back seat. I would like to no the specifications and I would greatly appreciate anyone that could tell me a little something about if this would work or why it would not work.
thanks sorry for the newb questions
if anyone can suggest something better im trying to stay under $500 total so im open to ideas
Tru NYY Fan is offline   Reply With Quote
Old 11-02-2007, 10:21 AM   #2 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
get rid of the sony 6x9 they won't last long.
you could get poineer, infinity, polk, alpine, jl audio, or jbl you could get some decent sound. the sonys will blow I know it. if you could get some of their old school set they're ok, but not the new series they have right now. You'll need an aftermarket amp indeed when you're putting that poineer in there. that HU has an internal amp so having an factory amp is a no go. I don't think the LEs have factory amps, but I might be wrong.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 11-02-2007, 01:56 PM   #3 (permalink)
http://www.crutchfield.com/App/Produ...0TSA6982&tp=91
whats difference between 3 way and 4 way and if I added all those things how many watt amp would i need idk if i add the peak of all those thigns or the rms
Old 11-02-2007, 11:47 PM   #4 (permalink)
View built2burn's Photo Gallery
i have that deck and i like it but its the premier one(comes with ipod cable)
you can pretty much ignore the peak and just use the rms
2/3/4 coaxail speakers is just the woofer + tweeters(2 tweeters on the 3way) i dont know if there a benefit to using more or not though
if you dont care about buying from non auth dealers(ebay and other stores) you can get an alright system for 500.
this is what im going to buy(i just gotta wait till spring because its cold now)
you can stay with that head unit(i paid 160 for mine with the ipod cable)
front speakers- phenix gold rsd front components(less than $100 on ebay)
i wouldnt bother with the rears(keep factory or just remove)
amp- cadence txa-3002($129 i think) or txa-3004($179)(3004 you can bridge to power a sub if you want one)
Knukonceptz.com for a wiring kit
built2burn is offline   Reply With Quote
Old 11-03-2007, 12:38 PM   #5 (permalink)
JayMax03's Avatar
if you are getting the 4-ways your going to need to amp them up so I would get a 4 channel amp for the fronts and rears.
if you are getting the 3-ways the highs are pretty good, but if you put too much bass in them you'll end up blowing the cones on them which makes a rattling sound before it completely goes out trust me on the 3-ways. 4-ways don't sound to good by themselves thats why you'll need an amp for it
3-ways (40 W RMS)
4-ways (80 W RMS) depending what 4channel amp you want to get always look at the watts RMS (nominal) not total peak power.
theAlpine MRP-F450 should do the trick unless you want to fall back into the Pioneer Premier series.
Old 11-03-2007, 04:56 PM   #6 (permalink)
Former Gen 4.5 owner
View Arisotezza18's Photo Gallery
What factory sound system do you have? If you have an LE, you most likely won't have a factory amp. The XLEs with the factory JBL system or similar premium sound are the ones that usually have the factory amp. You can check the plugs behind the factory HU to see which connections you have. If you have the traditional 2 plugs, you don't have a factory amp.
Arisotezza18 is offline   Reply With Quote
Old 11-04-2007, 01:04 AM   #7 (permalink)
xet
View xet's Photo Gallery
dont reuse the factory amp even if you have one, you need an aftermarket one
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
1997 Camry LE replace cloth manual seats with leather power seats...need wiring help! srkenjr9 Introduce Yourself Here 2 12-30-2008 10:05 AM
1997 Camry, V-6, LE, Great Shape $4,600/TX - PICS MustangDave Vehicles 0 10-02-2007 03:14 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
1997 Camry LE V-6 Warped Rotors/Cure Pearl Jam-5150 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-19-2005 06:16 PM
What factory radio years fit a 1997 Camry LE? Otto Man 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-28-2003 12:35 AM
