Amp Setup help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 12:46 AM   #1 (permalink)
View grant863's Photo Gallery
Amp Setup help
I have a Alpine MRP F240. I have a Alpine CDA 9847 head unit. I am trying to bridge my amp to run 1 pair of component speakers. I have 1 question.
To run 2 pairs of speakers this is the diagram the manual gives me
http://hermesproperties.com/untitled/untitled.JPG
And to run 1 pair of speakers bridged this is the diagram the manual gives me
http://hermesproperties.com/untitled/untitled2.JPG
I am confused as to what to do to run 1 pair bridged. The back of my head unit has 4 RCA ports like the first diagram which makes sense to me. Front and Rear. Can i just connect my RCAs like the first diagram says to bridge my amp or will that not work. I understand that the 2nd Diagram has a Y adapter, which makes sense for the amp but my headunit has a left and right front and a left and right rear, which one would i plug the Y adapter into? This is what i am confused with. I have a 4 Channel RCA cable that i used with my amp before
http://cgi.ebay.com/NEW-KnuKonceptz-...QQcmdZViewItem
but was running 2 pairs of speakers on my amp. Do i need a new cable..a Y adapter one? Any help would be greatly appreciated. Thanks
grant863 is offline   Reply With Quote
Old 11-23-2007, 06:41 PM   #2 (permalink)
Ok i have a follow up question...i think i might have figured my problem out...
So my 4 channel amp. I have 4 RCA cables. Do i just use a Y adapter and plug my 4 RCA cables into the amp and then plug the y adapter onto the other end of the cables thus having 2 RCAs to plug into my headunit instead of the 4. Then do i just plug those 2 y adapters into the Front and Left speaker outputs on the back of my headunit?
Any input would be greatly appreciated here...Ive done 1 install before and it worked out great but now im confused...or at least i'm hoping i was confused.
Old 11-24-2007, 12:05 AM   #3 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132050
View Jigg007's Photo Gallery
From what I got; you want to run two component speakers from a 4 channel amp, but bridged. (into 2 channels I presume) With most amps if you bridge it you're only going to use one input for the bridged output, not two. So if you're running a 4 channel amplifier into 2 channel bridged mode, all you should need is 2 RCAs connecting up to it. And at the deck you would just use the front or rear L+R outputs, respectively. I don;t see a need for any Y cables.
Hope this helps!
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Help with amp please built2burn Audio, Video, and Security - Tech 1 09-11-2007 07:31 AM
Please help camry amp install help Camryv6xle Audio, Video, and Security - Tech 2 08-12-2007 03:04 PM
Do I Even Need My Amp? Durrby Audio, Video, and Security - Tech 19 01-07-2005 05:59 PM
F... Did I blow my amp? Ruffrydasean Audio, Video, and Security - Tech 15 09-28-2004 07:52 PM
Amp for 2 of my Kenwood subs DarkMastyr Audio, Video, and Security - Tech 9 02-06-2004 10:10 AM
