Sub & Amp Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2007, 08:06 AM   #1 (permalink)
Sensible's Avatar
View Sensible's Photo Gallery
Sub & Amp Install
Hi. I'm new here so take it easy. What is the easiest way to add a sub&amp to the factory 2005 radio w/6-disc changer? System is with 6-speakers non jbl. I dont want to change the radio yet but I already have 12" sub and mono amp that I would like to add just to fill out the sound. Basically what is the remote turn on wire and how to get rca cable from radio to amp? Sorry for sounding noobish.
Sensible is offline   Reply With Quote
Old 11-24-2007, 11:36 AM   #2 (permalink)
View Mr Marv's Photo Gallery
Unless your amp has "hi level input" you will need to ad a line output converter to tap into the speaker wires and the RCA's will go from there to the amp. Also, most factory headunits do not have a remote turn on wire so the easiest way is to get a line out converter that also has signal sensing remote turn on capabilities. Don't forget you will have to run a power wire directly from the battery as well.
Mr Marv is offline   Reply With Quote
Old 11-24-2007, 12:31 PM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
use a line out put converter. hook up a switch so that would be the remote wire. dont worry about sounding noob-ish. everyone was in that stage once.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-25-2007, 03:46 AM   #4 (permalink)
View TbombsGen3's Photo Gallery
Mr Marv pretty much summed up your answer, but as a newcomer to car audio I highly recommend looking at the stickies at the top of the forum. The bace site is unreal. Has soooo much information it can almost be over whelming. Not there we arent here to help, but that will give you a huge head start.
TbombsGen3 is offline   Reply With Quote
Old 11-25-2007, 12:25 PM   #5 (permalink)
View thoughthard's Photo Gallery
A PAC OEM-2 converter might be make your install easier.
http://www.crutchfield.com/App/Produ...oem2&i=127OEM2
Install manual:
http://akamaipix.crutchfield.com/Man...27/127OEM2.PDF
I used one to install an aftermarket amp and sub into my 96 Ford Explorer. Made it quite easy. It was nice that it converted the factory 5V turn on into a 12V, with turn-on delay. I found mine, brand new on eBay, for dirt cheap.
thoughthard is offline   Reply With Quote
Old 11-25-2007, 04:30 PM   #6 (permalink)
Sensible's Avatar
Install manual:
Thanks for the info.
Old 11-25-2007, 10:31 PM   #7 (permalink)
Old 11-26-2007, 04:14 PM   #8 (permalink)
Sensible's Avatar
Lightbulb
edited......Thanks for the info.
Amp install questions corollapride Audio, Video, and Security - Tech 6 09-25-2006 10:23 PM
messing around triing to install and amp and poof smoke from under the dash chicagomac Previa Forum 1 05-15-2006 11:32 AM
Amp System Install to a Factory Stereo 96 Avalon avalonhyper 1st Generation (1995-1999) 3 02-17-2006 11:14 PM
Amp Install on TC RanmaP 1st Generation (2005-2010) 2 09-04-2004 04:50 AM
$75 to install HU amp and sub... good? Mighty~Mart Audio, Video, and Security - Tech 3 08-27-2003 12:16 AM
