amp help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2003, 08:26 PM   #1 (permalink)
geo
View geo's Photo Gallery
amp help
trying to install new pioneer dvd monitor to existing system. does any one know how to use stock amp with aftermarket head unit? need help.(can it even be done?) land cruiser.
geo is offline   Reply With Quote
Old 09-22-2003, 10:14 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
There is a harness from Metra (I believe) that will adapt from RCA of any aftermarket source to the OEM single preamp plug that will feed the OEM amp. However, this is NOT a long-term solution as whenever the aftermarket unit is turned on, there is a nasty loud pop and picks up noise also. This isn't because of the harness adapter, but because of the OEM amp'd system, as it uses a shielded harness bundle. In addition, the higher RCA output voltage may contribute to the noise popping that feeds the OEM amp, which accepts a much lower input. The best thing to do is to bypass the OEM amp and use the amp section in the Pioneer hideaway unit instead.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
