Good Quality Class AB Amps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 10:12 AM   #1 (permalink)
View HuskerTRD's Photo Gallery
I am installing a new custom audio system in an '08 Tacoma Double Cab and am looking for some high end good quality Class AB amps. I need the following amps:
  • 4 channel amp capable of producing at least 4x100watts RMS at a 4 ohm load
  • 1 channel amp capable of producing at least 300 watts RMS at a 4 ohm load
I was planning on getting both Eclipse amps XA1000 and XA4000 however these are class D amps and I have been told class AB amps produce much greater sound quality.
Does anyone have any suggestions or experience with class AB amps in the power range I am looking for?
Thanks
'08 DC TRD Offroad 6spd, DR Coilovers & Rear Resi's, TC UCA's, Alcan 8-leaf pack
HuskerTRD is offline   Reply With Quote
Old 12-05-2007, 08:01 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Arc 4200SE
4x111W @ 4 ohm
2007 Camry 2.4L 5M
Old 12-08-2007, 09:45 PM   #3 (permalink)
View Mr Marv's Photo Gallery
Thanks
Is it possible for you to try out those amps yourself at a local shop? I'll bet you'd be hard pressed to "hear" a difference with all else being equal.
Mr Marv is offline   Reply With Quote
Old 12-09-2007, 10:07 AM   #4 (permalink)
Unfortunately I have not found a shop around here that carries them, plus I plan to buy everything online from woofersetc.com they seem to have very good prices.
After doing some more research I am leaning toward the Zapco REF 1000.4 and 500.1. For a little bit more money they seem like a better product.
Old 12-09-2007, 10:39 PM   #5 (permalink)
WoofersETC is not an authorized Zapco dealer and Zapco does not authorize sales over the Internet. Your warranty will be voided if you buy from WoofersETC.
http://www.zapco.com/ZapcoBuyersBeware.htm
2007 Camry 2.4L 5M
Old 12-10-2007, 08:42 AM   #6 (permalink)
Well after all it ends up I am going to be installing both of the Eclipse amps previously mentioned. Unfortunately the Zapco amps break the budget.
As Mr. Marv mentioned the sound quality in comparison from a class AB amp in comparison to a class D amp is most likely negilgible.
Good and Affordable subs cam2Xrunner Audio, Video, and Security - Tech 36 09-07-2007 09:14 AM
Class D mono amps Toyogook Audio, Video, and Security - Tech 32 05-23-2006 04:38 PM
Very fine restaurant in Markham/Richmondhill? EKam Off Topic 38 02-08-2006 03:24 PM
Good SQ/Thumping Sub, and matched amp? Mushroom_Toy Audio, Video, and Security - Tech 19 07-03-2005 03:01 PM
Is this dash kit on ebay any good quality? DaSaiGoNDoN216 Camry & Solara Lounge 10 04-30-2002 06:40 PM
