You guys ever wanted a small subwoofer, but just can't afford the big size? Here's the solution:
It's around 10 inches and can provide over 100-watts of RMS, it can be set up vertical or horizontal to meet your compact needs. It's MSRP is 58 bucks!
What do you guys think?
T/S Parameters:
Fs
60Hz
Qms
3.4
Qes
1
Qts
0.79
Bl
5.6
Mms
44g
Cms
0.16mm/N
D
15.8cm
Sd
196cm^2
Vas
8.9ltrs
Sensitivity (1W/1m)
84.5dB
Recommended Power
100watts
Freq. Range
50-300Hz
Dimensions
10.24" x 3.5"
Weight
1.86 lbs
http://www.audiojunkies.com/blog/871...t250-subwoofer
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
