Originally posted by Axl Rose
[B]series would be from +ve to 1st sub, 1st sub to 2nd, 2nd to -ve right?
Your right, but the way your explaining it is kinda confusing. I understand what your saying though.
So how would you hook subs up in parallel? Are we just talking about off two chennels like i have, or is there a way to run 2 subs of ONE channel through parallel (wouldnt that underpower them chronically)
+ of sub 1 to + of sub 2. Same for the negative.
Both subs will get the same amount of power.
Imagine the subs as resistors. Say you got 12 volts going to 2 resistors (both of them are the same) wired in series, each resistor would get 6 volts.
The same resistors wired in parallel would see 12 volts each.
Now i have it all drawn and its all good, but i am concerned with
a) will the LEDS draw too much current and my amps wont turn on (as in no remote)
b) is there eeven enough power in a remote lead to run 2 LED's
The amp turn on lead on decks is a low current output. So if your going to turn on a bunch of stuff (multiple amps, x-overs, eq's, etc....). Its best to use a relay.
