Gen6 Camry Speaker Templates - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2008, 06:24 AM   #1 (permalink)
View eipromb's Photo Gallery
Gen6 Gen6 Camry Speaker Templates
I've just started re-changing my car speakers, formerly with RF Punch 3-ways. I'm now going towards a DIY approach using a combination of Dayton RS150's, ND28's, and a RSS265 for a sub. No pictures yet, but seeing as I could find any printable templates to use to make the speaker brackets, I made my own. I just wanted to share for the time being while I get the rest of my system installed.
http://www.electricallyerasable.com/...07_tweeter.pdf
http://www.electricallyerasable.com/...ry07_front.pdf
http://www.electricallyerasable.com/...mry07_rear.pdf
I think they work with the gen5 Camry's and Tacoma's too.
As a side note does anyone here have an experience putting together crossovers? I've read up on it, but assistance with construction would be of great help. I think I'll be doing a 3rd order Butterworth at 2500Hz.
eipromb is offline   Reply With Quote
Old 02-24-2008, 12:38 AM   #2 (permalink)
View Philippe's Photo Gallery
Thanks for the post. Unfortunately, the site you reference appears to be down. Any chance you could post those directly here, or use another site that's working?
I could really use those templates, as I have just discovered that the "pro" installer who put the Bostons in the front of my 2000 Camry did a horrendous job, and I need to make new brackets to fix the problem.
Thanks either way
Philippe
Philippe is offline   Reply With Quote
Old 02-24-2008, 09:41 AM   #3 (permalink)
Thanks for sharing that with everybody!
Will this template fit a Gen 4 (2000) Camry well?
I need to install some door speakers in mine.
Thanks.
Philippe
Old 02-24-2008, 10:28 AM   #4 (permalink)
View Mr Marv's Photo Gallery
The Generation 6 are similar however not quite the same as the Generation 5 and Tacomas unfortunately.
Mr Marv is offline   Reply With Quote
Old 02-24-2008, 10:30 AM   #5 (permalink)
Thanks.
Philippe
Toyota likes to change the design with every generation so these will not fit your Gen 4
Old 02-24-2008, 11:22 AM   #6 (permalink)
anyone have template for 200 Camry door speaker brackets?
Hey thanks Mr. Marv. You're somewhat famous around here. :-)
This of course begs the question, does anyone else have a template for a gen. 4 or Year 2000 bracket for Camry door speakers?
Thanks in advance.
Philippe
Old 02-24-2008, 08:07 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Thanks.
Philippe
These templates will definitely not work in your Gen 4. Gen 4 has 6.5" speakers in front. You don't need adapters really. Get some 6.5" or 6.75" speaker and you can mount them directly to the car. You just need to drill 4 holes for the screws.
For the tweeter, I just metal tape with holes. That tape is usually use to hang pipes or secure water heaters to the wall and such.
2007 Camry 2.4L 5M
Old 02-25-2008, 10:46 PM   #8 (permalink)
Canada
Maybe according to some spec sheet, but all I can tell you is that in my car, the holes in my doors will not proper mounting of my particular Boston 6.5s .
My Boston RC620s 6.5s do not fit properly in the pre-existing holes. There is also not enough metal around the periphery of the mounting hole for the Bostons to screw into the surrounding metal with more than two screws. Worse yet, those two screws have to be on one side of the driver in order for them to fit. I discovered this after the local so-called "expert installation shop" messed up the job. Hence my reasons for creating the baffles.
Shplad
Old 02-25-2008, 11:07 PM   #9 (permalink)
Shplad
Odd...
I had a Gen 4.5 (2000) Camry and I managed to put a 6.75" component set in the front doors without baffles. The speakers fit in the hole and the metal lip was sufficient in size that I was able to drill 4 holes and mount the speaker to the door. I did not use the pre-existing screw holes.
2007 Camry 2.4L 5M
Old 02-27-2008, 03:52 PM   #10 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
so I take it by the look of these templates....
1. Just get a thin sheet of metal
2. Cut out the templates
3. Cut the holes out of the center of the template to make the speaker fit
4. Mount speakers
Am I wrong?
Thanks for the replies in advance.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 02-27-2008, 06:16 PM   #11 (permalink)
4. Mount speakers
Am I wrong?
Usually people use MDF, but metal should work also.
2007 Camry 2.4L 5M
Old 02-27-2008, 06:22 PM   #12 (permalink)
ebumdude's Avatar
Gen6
Right on....thanks again TC for the helpful info.
-09' Venza
Old 03-01-2008, 03:06 PM   #13 (permalink)
These templates will help a lot of people but if you're going to the trouble of building crossovers, why not go with active crossovers instead?
I guess maybe if stay with the stock HU, you may want to build them, but you could get a DSP to do the same thing.
2007 Camry 2.4L 5M
Old 03-02-2008, 01:52 PM   #14 (permalink)
If somebody with a generation 6 Camry will send me one of their original speakers as well as a couple of pictures of the door with the speaker removed I will make them a set of custom baffles for free.
Old 04-30-2008, 08:00 AM   #15 (permalink)
I finally found the time to mount the speakers (its been a while!) I used 1/4" MDF for the tweeters at first but it came out too tall to fit the cover back on, I ended up using a blank copper/fiberglass circuit board instead. Here are some pics:
08 Accord EXL-V6 vs Camry SE krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 17 05-22-2009 10:12 PM
Camry Rear Speaker Harness Convert Audio, Video, and Security - Tech 1 03-14-2009 06:36 PM
Gen 5 Camry XLE Speaker Upgrade Convert Audio, Video, and Security - Tech 28 05-05-2008 01:51 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
